Engine stalls in reverse
Old Dec 14, 2009 | 12:36 AM
Rammanator's Avatar
Rammanator
Default Engine stalls in reverse
Ok so my 94 1500 v8 5.9ltr has a little prob when I put it in to reverse it stalls. Now it doesn't do it any other time only in reverse. Any ideas why its happening?
Could it be plugs? Motor idles perfect in N .
niko.
Old Dec 14, 2009 | 06:14 AM
95RAM360's Avatar
95RAM360
did you already post a topic on this?
Old Dec 14, 2009 | 06:53 AM
halfamil's Avatar
halfamil
Check the transmission fluid.
Old Dec 14, 2009 | 02:44 PM
Rammanator's Avatar
Rammanator
Nop wasn't me that posted it. Also why would trani fluid have a effect on the motor running?
Old Dec 14, 2009 | 02:50 PM
95RAM360's Avatar
95RAM360
ok just wanted to know so i could take the other info into consideration...
theres more strain on the motor in reverse...almost double as in drive. so it would need alot of fluid, or it dumps into "limpmode" i believe. also too much tranny fluid will cause shifting problems as well...but to kick the motor down....i dont think fluid could do that
Old Dec 14, 2009 | 03:44 PM
Rammanator's Avatar
Rammanator
Will go out and check level, and maybe change spark plugs too.
Old Dec 16, 2009 | 12:14 AM
Rammanator's Avatar
Rammanator
So had a look at the fluid level and it's low, I'm changing the oil tomorrow and filter and will see how it goes from there.
Old Dec 16, 2009 | 08:12 PM
Rammanator's Avatar
Rammanator
So changed the oil and filter today and man was the oil dirty. Also there was traces of brass and metal in the pan and on the filter.
Now the truck seems fine in reverse with no stalling.
Another happy camper : )
Old Dec 16, 2009 | 10:06 PM
halfamil's Avatar
halfamil
Traces of metal is normal for one that has not been changed in a long time.How many miles are on it?
Old Dec 16, 2009 | 11:08 PM
Rammanator's Avatar
Rammanator
220,000 on the motor but I'm not sure on the trani as there's a aftermarket service sticker on the pan side.
Had a good drive tonight and gear changes were normal.
