what are bad fuel pump symtoms?
Old Dec 15, 2009 | 05:40 PM
dodged again's Avatar
dodged again
Default what are bad fuel pump symtoms?
I have a thred on here under out of town need dodge help but im not getting much response.Anyone had a fuel pump to go out,and if so what were the symtoms?
Old Dec 15, 2009 | 05:41 PM
Laramie1997's Avatar
Laramie1997
No sound and lack of flow of go go juice.
Old Dec 15, 2009 | 05:45 PM
silverbullet-dodgeram's Avatar
when mine went out it would kinda shutter and i would put the petal to the floor and few sec later truck would just take off
Old Dec 15, 2009 | 05:47 PM
seabass202's Avatar
seabass202
intermittent no/long time to start, an audible whine, some nursing techniques include cycling key of and on to build pressure before trying to start and in the very last stages of failure a good kick to the bottom of tank can get you a couple more starts.fuel pump failures skyrocket in cold weather.
Old Dec 15, 2009 | 07:41 PM
MAJohns's Avatar
MAJohns
usually wont start beet on the gas tank and it will crank
Old Dec 15, 2009 | 07:45 PM
cmckenna's Avatar
cmckenna
Other symptoms include bogging down in the feel, low throttle response, lack of power under loading conditions such as going up hill, hard starts regardless of temp, and misfires due to lean fuel mix.
The air amount remains the same while the flow rate drops due to low output of the fuel pump thus causing a misfire across all / multiple cylinders.
Old Dec 16, 2009 | 12:11 PM
Aubrey's Avatar
Aubrey
And if your gauge is out of wack.
