my truck (2001 ram 1500 5.9 2x4) just starting almost like jolting at certain speeds (45-50) it still shifts fine and if i floor it it comes out of the jolt but i cant figure out what could be causing this any help would be appreciated.
ive turned overdrive off and it helps a little but nothing drastic.
and my transmission still shifts easy and its only if im in a certain rpm at a certain speed range(45-50)
fuel filter? better hope not that part of you pump. if it is you get to by a new one and drop the tank or pull the bed. i pulled my bed when i did mine but i put a goose neck ball in it at this time to, but it wasnt to hard
Originally Posted by zpa1993
could it be anything to do with the injectors,fuel filter, anything cheaper to fix
