Any Guys running gutted cats?
how did you determine that your cat was clogged -- im feeling a lack of power under power at high rpms, and poor gas milage, (and if i lay on the gas the check engine light will start blinking) ...but i pulled out that o2 sensor right in front of the cat and didnt really notice a difference, just got louder...
i just replaced my plugs, dist cap and rotor, they were pretty fowled. the problem got better after that but is still there... thanks~
It is possible you have a blown plenum gasket
Ugh. I've heard it said that every 2nd gen dodge on the road has a leaky plenum gasket, its just a matter of how much.
Anyway, I reved the engine and after holding it at ~ 3000 rpms for a few moments going up a hill the check engine light started its blinking, and I got these codes: p0306 p0300 p0302 p0304 all engine misfire codes. What would do that?
I have a question here. I heard some people's gas milage went down from this. And not from a heavy foot either. Atleast thats what i think ive read. I cant really afford any worse milage than im getting. I thought i was getting perdy good gas milage untill i figured out i was calculating wrong. And acually im getting like 10.8-11 MPG... Will my gas milage go down? Obviously if milage goes down then it does effect somthing other than sound.... I dont want my truck to run rich from this either. Did i read wrong? Will running with no cat truely do anything besides make it sound great? Just wondering before i take my cat off. I am planning to do so after Christmas. Cant wait! Im not going to gut my cat tho. Im going to put a peice of pipe there in its place. That way there will be more back pressure than with just gutting that big peice of steel.
im new here and im not the smartest mechanic around either when it comes to automobiles. i do know a bit though. my expertise are motorcycles and ATVs. my opinion on losing gas mileage with a free flowing cat-honestly, i dont see how it would cause your mileage to go down. if anything it would get better. less restriction=more power, better flow. less restriction=better mileage. it will not cause your truck to run rich either. if anything, lean but thats where the computer and fuel injection come in play. it will adjust automatically. as for this so-called "back pressure". i wish some one could explain this to me. what is back pressure supposed to do and be? thats got me confused. from my understanding and experience, the freer flowing the exhaust, the better. just my $0.02.
It is understood that too little backpressure will harm low end torque. This is true in some respects. The key to an efficient exhaust system is exhaust velocity. A free flowing exhast pipe that is too large creates a slower gas velocity, hurting power.
That's it in a nutshell.
Vacuum leak, clogged fuel injectors &/or worn rotor/cap/wires some of the more likely.
I gutted my cat after it plugged up on me. I was an hour away and had the g/f bring down to me the sawzall. I cut the cat off and drove home with open headers. lol It sounded pretty aggresive. Oh yeah this was last year after 12 inches of snow. Why can't this stuff go bad in the nice weather. I hollowed out the cat with a pry bar and had the local mechanic weld it back up for me. So far the c.e.l. only goes on after I leave it idling for long periods of time. I do have a Flowmaster muffler that makes it sound nice too. As for the emissions testing for inspection if you have the type where you have some put a probe in your tail.....pipe you more than likely will fail. How ever if they only plug into the dash OBD2 port your good as long as there are no check engine lights. I did some digging if you start having the c.e.l. come on you can purchase something called a cat delete box. You wire it into the harness where you would put the O2 Sensor and viola, no light. Ahem for off road use only
Good luck
Good luck
