New Water Pump whining
Old Dec 19, 2009 | 12:29 AM
95RAM360's Avatar
95RAM360
Default New Water Pump whining
ok i have only 8K on my brand new (not remaned or used) water pump and fan clutch, 16K on a brand new radiator, 1K on hoses and thermostat.
now the trucks heat and temp and everything is fine, but i can hear the water pump whining. it sounds like its comming from inside the water pump, not outside. gets louder as i hit the gas, and sometimes it goes away. its not loud byany means. by its enough where i can just here it when inside the truck, and when under the hood its loud enough for me to pinpoint where it is.
any help would be great.
Old Dec 19, 2009 | 01:55 AM
95MaroonMonster's Avatar
95MaroonMonster
bad bushing maybe?
Old Dec 19, 2009 | 02:09 AM
Dodge.Ismo's Avatar
Dodge.Ismo
That's happened to me a couple times...spray some WD-40, (or jiffy lube), onto pulley shaft area while running...usually noise stops...unless you got a bum pump with a crappy bearing/bushing...
Old Dec 19, 2009 | 07:03 AM
95RAM360's Avatar
95RAM360
got the water pump from car-quest
and thanks im going to try that before i go to work today
Old Dec 19, 2009 | 01:34 PM
Dodge.Ismo's Avatar
Dodge.Ismo
Right on 95RAM360,...I usually..., (after fixing/modifying the chassis/engine), oil guard the whole truck...including the engine compartment. No squeaks or squeals on my truck! *(I mix..i- gallon mixture of 30% varsol,..50% tranny oil,..and 20% "RustCheck" oil), loads up my spray gun,..put compressor to 40 p.s.i., ..and blast away.. chassis..springs,..axles...everything...door jambs,..engine compartment, under hood,..engine + trans.,.. front end,...**(for inner roof,..and pillar posts etc.,.. I drill a few holes,..and get the rubber plugs from "RustCheck" to ...plug 'em!...DONE DEAL!!
Old Dec 19, 2009 | 07:00 PM
lord0fsal3m's Avatar
lord0fsal3m
thats a pretty good idea, i think im gonna start doing something like that
Old Dec 19, 2009 | 08:41 PM
95RAM360's Avatar
95RAM360
the WD made her come out of it...now since that covered up the problem should i worry about anything blowing? i have to make a 600 mile round trip next week, and i dont want problems
Old Dec 20, 2009 | 01:08 AM
Dodge.Ismo's Avatar
Dodge.Ismo
I've done this, (WD-40 spray), many times on many vehicles,...and it's usually just "dust" or just plain lack of lubrication from the factory in thier parts..or evaporation,..(sitting on shelves disipates lubricants..). I've never had one seize on me that I sprayed for "squealing".
