4 wheel drive issue
Old Dec 19, 2009 | 01:31 PM
Gtram43's Avatar
Gtram43
Default 4 wheel drive issue
Hello, the probem with my 99 ram 4x4 is this, truck will not engage into 4 high, I tried it in 4 low and I can pretty much tell that it is going into 4 low, although there is NO indicator light coming on either way. I have 1 vacuum hose coming from the CAD to a free hanging end with a plastic nipple on the end, surprised this isnt connected to anything. What do you guys think the problem could be as its not going into 4 high and no light?
Old Dec 19, 2009 | 01:39 PM
offroadjosh's Avatar
offroadjosh
Well sounds like your vacuum disconnect is toast. Time to order a new one! Common problem on the rams.
Old Dec 19, 2009 | 01:51 PM
Gtram43's Avatar
Gtram43
Where is that located? You mean the piece at the end of the hose? Sorry but Im not familiar with that.
Old Dec 19, 2009 | 02:28 PM
offroadjosh
The switch is located on top of the t-case.
Josh
Old Dec 19, 2009 | 02:39 PM
Miami_Son's Avatar
Miami_Son
You might want to read through this thread and do a search for others. Very common problem with these trucks.
https://dodgeforum.com/forum/2nd-gen...078-no-x4.html
Old Dec 19, 2009 | 02:46 PM
Gtram43's Avatar
Gtram43
Thanks, I did more checking and found some very brittle vacuum lines so Ill start with that, have about 4 hours before the blizzard arrives here in rhode island so Im gonna try to beat the clock, again thanks for the help guys.
Old Dec 19, 2009 | 03:59 PM
95RAM360's Avatar
95RAM360
get the posi-lok.....
Old Dec 19, 2009 | 07:02 PM
ms96ram1500's Avatar
ms96ram1500
My Ram will go into 4hi easy but won't shift over to 4lo
______________
Old Dec 19, 2009 | 07:30 PM
offroadjosh
Check your linkage.
Josh
