automatic transmission part
Old Dec 20, 2009 | 09:02 PM
NoBallZ59's Avatar
NoBallZ59
Default automatic transmission part
so this past weekend i did a tranny service on my 04 cummins with a 48re auto in it. had troubles with the truck not starting off in first all the time. was told it was the gov. solenoid and transducer. well i replaced them and put in a new filter and fluid. anyway, on the magnet i found a small piece of curved metal measuring about 2" long, 1/16" thick and 1/4" wide.
after looking up in the tranny some i found another similar piece only longer. ends actually meet up, telling me it once was one piece also that there is another half still in the tranny, i just dont know where.
i know these being outside of the tranny cant be a good thing, i just dont know what they are. can anyone give me a little insite on what these(this) piece is and what its function is?
on a side note, the tranny does shift much better now. but sometimes hangs in gear(1st) longer than it should.
Old Dec 24, 2009 | 12:23 AM
hydrashocker's Avatar
hydrashocker
You are in a dead area and you need to post in your era of year of make.
Dodge Cummins Diesel
Discuss all generations of Cummins Diesel powered Ram's within Dodge Diesel Forum.
~Rustin~
Old Dec 24, 2009 | 09:54 AM
Coal Train's Avatar
Coal Train
That's a snap ring.
More than likely it's the snap ring that holds the drum in place.
I hate to say it, but the tranny needs to come apart.
Hopefully it didn't tear up any of the internals.
Old Dec 24, 2009 | 09:57 AM
95RAM360's Avatar
95RAM360
ive heard of something with the gears needs to be welded in? cuz something pops out of one of the gears, its a known problem in the cummins from what i hear.
sorry i couldnt be more specific.
Old Dec 24, 2009 | 10:28 AM
Coal Train's Avatar
Coal Train
It's not on that tranny, that problem is on the NV4500.
The NV4500 has a tendency for the 5th gear nut to back off. One of the "home" fixes is to tack weld the nut in place. It works for a while, but high HP trucks tend to break it.
Old Dec 24, 2009 | 01:57 PM
ecwrestoration@yahoo.com's Avatar
Trannny's done!! had the same thing happen to me last month, $3,500. will fix that. had everything rebuilt HD w/shift kit & billet convertor. Good luck
Old Dec 24, 2009 | 09:06 PM
95RAM360's Avatar
95RAM360
^ that is exacally what i was talking about
i thought that this caused your problem...but i guess not
Old Dec 24, 2009 | 09:09 PM
PurplDodge's Avatar
PurplDodge
How the hell did this get moved to the 2nd gen section?
That is a snap ring for your overdrive. Let me do some searching and I may find exactly what it is.
Old Dec 23, 2011 | 07:02 PM
Tranyguy's Avatar
Tranyguy
Thats your direct clutch retaining snap ring. I've been rebuilding for Dodge since 89 and have seen this dozens of times.
Old Dec 23, 2011 | 07:16 PM
UnregisteredUser's Avatar
UnregisteredUser
Haven't been using online forums for very long, though, eh? The thread you're making noise in has been inactive for two years.
Welcome to DF!
