Climate controls backwards?
Old Dec 21, 2009 | 10:26 AM
bigtman07's Avatar
bigtman07
Default Climate controls backwards?
Ok so I was riding with the ol' lady's dad yesterday in his 1999 2500 with the 5.9, He said hey check this out. And he reaches over and turns the Air Conditioning. And out comes the heat full blast???? I'm like WTF? Hes like yea i know. He said the cable in the dash is messed up. I didn't know we had a control cable to control the climate control. So I thought I would look on the forum and the search has left me empty handed. So anybody have any ideas the cause to why the air conditioning is the heat and the heat is the air conditioning?
Old Dec 21, 2009 | 11:46 AM
PurplDodge's Avatar
PurplDodge
How cold was it out?
There are no cables behind the dash. Only vaccum lines.
Old Dec 21, 2009 | 01:31 PM
bigtman07's Avatar
bigtman07
Thats what I thought but he said there was a cable connecting the heater to the ac and its out of adjustment. I think he's full of it but w/e. As far as the temp goes it was around 30* outside. truck was warm. Just strange on the controls.
Old Dec 21, 2009 | 05:00 PM
PurplDodge's Avatar
PurplDodge
The only two things that control behind the dash are vaccum acuators and electric motors.
Old Dec 21, 2009 | 10:39 PM
dhvaughan's Avatar
dhvaughan
if you turn the selector to MAX AC, and rotate the temp dial to hot, it will blow hot air. is that what your talking about ?
Old Dec 22, 2009 | 10:35 AM
bigtman07's Avatar
bigtman07
Nope. Turn it to cold and max A/C and you get heat. The other Way is the A/C. So the only thing that came to mind was that the lines are backwards. But how on earth could that happen without pulling the dash and flipping the lines?
Old Dec 22, 2009 | 11:43 AM
PurplDodge's Avatar
PurplDodge
Does it do that in the summmer too?
His blend-air door may be messed up.
Old Dec 22, 2009 | 02:07 PM
bigtman07's Avatar
bigtman07
Dunno about the summer we don't use the air that much. So this blend air door is a vacuum operated door that switches between the heater core and the A/C?
Old Dec 22, 2009 | 07:49 PM
PurplDodge's Avatar
PurplDodge
Its an electric motor that operates a door that moves air through the heater core or the a/c evaporator.
Old Dec 22, 2009 | 11:32 PM
bigtman07's Avatar
bigtman07
Ahhhhh ok. So I wonder how hard that would be to replace if it is bad? I still wish I knew how it could get backwards if its a motor??
