burns 3 quarts in 250 miles
Old Dec 25, 2009 | 02:30 PM
01ramjam's Avatar
01ramjam
Default burns 3 quarts in 250 miles
I have a 1999 witha 360 and its burning about 3 quarts in about 250 miles.I read on here about the plenum so im gonna go ahead and get that changed when the part store opens monday. But i was wondering if there is anyway to check for the piston rings without puling the motor apart?
Old Dec 25, 2009 | 02:36 PM
2001Ram's Avatar
2001Ram
Compression test..
Old Dec 25, 2009 | 02:41 PM
01ramjam's Avatar
01ramjam
150psi??
Old Dec 25, 2009 | 06:37 PM
Hammer Down's Avatar
Hammer Down
thats not spectacular, but not too bad either for a 10 year old truck. The plenum probably is a contributing factor, but I have never heard of a truck burning that much oil that quickly. Are we sure there are no leaks?
Old Dec 25, 2009 | 06:47 PM
dhvaughan's Avatar
dhvaughan
i'd call 3 qts in 250 miles a SPECTACULAR leak. order the hughes kit on monday and it'll be there by thursday or friday.
+1 on compression test to check your rings, but i'd think you'd have a LOT of blue smoke with a leak that bad.
another problem that can burn a lot of oil is the rubber valve seals. they tend to smoke more at low rpm and and less at higher rpm.
assuming your not leaking this oil out on the ground, after you get it fixed - check your plugs, 02 sensors, and catalytic converter. they might be shot.
Old Dec 25, 2009 | 07:35 PM
2001Ram's Avatar
2001Ram
Burning 1 quart of oil ever 85 miles is ALOT! I bet you get terrible MPG too. The plenum might be a little of the problem but I doubt its all of it. Check for leaks +1
Old Dec 25, 2009 | 11:03 PM
95MaroonMonster's Avatar
95MaroonMonster
i think he was talking about the compression test
actually 150 is not bad
Old Dec 25, 2009 | 11:05 PM
Hammer Down
Sorry. I probably should have been more specific. I was talking about his compression.
Old Dec 25, 2009 | 11:19 PM
dhvaughan's Avatar
dhvaughan
LOL. i know.
150 psi compression is pretty good.
you got to admit - 3 qts of oil in 250 mile is spectacularly bad.
Old Dec 25, 2009 | 11:21 PM
Hammer Down
LOL. i know.
Really? lol He's running like a 2 cycle.
