Plenum Questions
Old Dec 25, 2009 | 07:43 PM
2001Ram's Avatar
2001Ram
Default Plenum Questions
So, I got the Hughes kit today for Xmas. I have everything torn apart but I noticed that a couple of small pieces of gasket have fallen down next to the rods. I got what I think is all of it out. Here is my question. Should I take a small suction thing and suck all the little pools of oil out. I noticed a small amound of sludge on the wishbones too. If I got a lint free rag, would it be ok or do more bad than good?
I will change the oil immediatley after the plenum is fixed.
Here are a couple of picts:
Old Dec 25, 2009 | 07:51 PM
Hammer Down's Avatar
Hammer Down
I would just make sure all of the gasket material is picked out. The sludge can be handled with a oil change after the engine has warmed. Some seafoam in the crankcase before the oil change could help clean it up.
Old Dec 25, 2009 | 08:07 PM
PurplDodge's Avatar
PurplDodge
Id take that sticker off before you put it back on.
Old Dec 25, 2009 | 08:12 PM
2001Ram's Avatar
2001Ram
Ha yeah the sticker will not go in, its just taped on. Actually I already took it off. I was just worried thinking the worst that a piece of gasket I didnt see went into the oil pump and locked it up. If you guys say itll be fine, then I will just change the oil after. This sludge though, is thick stuck on sludge. Oil change isnt going to get rid of it. I mean its not bad, just a small amount. Ive seen ALOT worse on the engines Ive torn apart.
Old Dec 26, 2009 | 07:20 AM
Sheriff420's Avatar
Sheriff420
i had some crispy stuck on sludge in a few spots in the lifter valley, i just soaked up all the oil and picked at all the sludge to get it out of there. i think it'll be fine on mine. but i didn't have the same type of gasket as you, mine was a metal compression gasket so i didn't lose any pieces. hopefully your pieces are small enough to come out with the old oil when you change it.
