Indy cylinder head screwed up
Old 12-26-2009, 11:38 PM
Trey318's Avatar
Trey318
Trey318 is offline
At least you found the culprit <.<
Old 12-27-2009, 07:13 AM
charlie1935's Avatar
charlie1935
charlie1935 is offline
Originally Posted by babyhuey6810
With all due respect the fault lies with the installer.If I put a ring on a piston with 20 thousandths of vertical slop its telling me something is ...askew!They might throw you a new set to make things right,but thats the end of their culpability.Did you get pistons too?If they sent you pistons and rings together with the wrong rings I would be raising hell.But its still your job to check that when assembling the shortblock.It had to smoke like a detroit diesel while it was together.
Absolutely!
Old 12-27-2009, 11:21 AM
jbomb's Avatar
jbomb
jbomb is offline
and they did
Old 12-27-2009, 12:25 PM
babyhuey6810's Avatar
babyhuey6810
babyhuey6810 is offline
I understand they forked up your order and they should replace the incorrect parts,but it still falls on the assembler to check clearances.I have seen rings put on upside down,standard rings on o/s pistons,ring gaps lined up together,and dont get me started on crank clearances.I check everything 2 and 3 times,because the guy that says its probably ok aint gonna be there to help you pull it back out.Everyone eats a crap sandwich now and then,just be happy you didnt break all your piston skirts
Old 12-27-2009, 04:19 PM
jbomb's Avatar
jbomb
jbomb is offline
I am not saying that we should have no blame in the issue. but we recieved a kit complete with all contets from a VERY well know vendor/manufacuer.
Old 12-27-2009, 04:21 PM
jbomb's Avatar
jbomb
jbomb is offline
Going to call muscle motors (if you dont know them then you should(one of the finest mopar shops in the country)) to possibly take my motor there when we get it together and have them break in the rings on the dyno.
Old 12-27-2009, 05:01 PM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
Who did you receive said parts from? I would like to know.
Old 12-27-2009, 09:26 PM
jbomb's Avatar
jbomb
jbomb is offline
All straight from Indy.
Old 12-27-2009, 09:29 PM
jbomb's Avatar
jbomb
jbomb is offline
And because cast, hypertectic, and kb pistons all require different ring gaps we asked indy when we bought the kit. They told us was that they did not know because they got the stuff from mopar. When calling this last time to ask them they got incredibly ****ty with us. Wow just want to know what piston this is to build this right.
Quick Reply: Indy cylinder head screwed up
