Custom Gauges
Old Dec 26, 2009 | 10:59 PM
Cheat's Avatar
Cheat
Default Custom Gauges
Does anyone know how hard it would be to put a custom gauge set up in my truck, No not like oil pressure or anything like that, Like custom speedo and fuel guage. Like this one: http://www.glowshiftdirect.com/elite...ter-gauge.aspx
I just wonder how hard it would be. It would look nice in the end though.
Opinions?
Old Dec 26, 2009 | 11:10 PM
95MaroonMonster's Avatar
95MaroonMonster
you mean like a whole custom gauge panel??
wouldnt be too hard to make them work, but getting them packaged in the factory location without hacking the hell out of your gauge panel would be a pain
agreed though, the end result, if done correctly would look killer, i considered doing the same, except with Autometer procomp gauges
Old Dec 26, 2009 | 11:23 PM
Cheat's Avatar
Cheat
If I do it it would have to have the whole cluster removed and then get a custom gauge panel made. Thick sheet metal. Then i would have to find a light for my cel and ect lights. Do you think it would through a cell for the cluster not being there?
Old Dec 26, 2009 | 11:54 PM
95MaroonMonster
not if you transferred everything thats on the back (i thinks there's like some computer boards and what not back there
i had an idea awhile back, i was planning on a cummins swap (not anymore) i was going to make my own panel to fit in place, out of brushed aluminum and get some small indicator lamps (the style used on older semi trucks) and label them for everything
Old Dec 27, 2009 | 12:03 AM
Cheat's Avatar
Cheat
Yea thats what I was wanting to do, But i dont want to leave all the computers and stuff in the back. Ill be using all new gauges. So the old cluster would be put away and all the wiring would be spliced for the new gauges and lights, I am just conserned about it not wanting to work because the cluster isnt seen by the pcm and it keeps the cel on. You think it will?
Old Dec 27, 2009 | 12:08 AM
95MaroonMonster
eh, it should work, just label EVERYTHING!!!!
i cannot stress that enough, electrical gremlins are a bitch
Old Dec 27, 2009 | 12:14 AM
Cheat's Avatar
Cheat
Lol, Trust me I know this. Im thinking about using the wire tappers and tapin the connector for the cluster off and just using fully wire taps but you know how thoughts things work.
I wonder how many guages i can stuff on a panel the same size as the old cluster? hmmm.
Old Dec 27, 2009 | 12:18 AM
95MaroonMonster
id say stick with the factory 6 gauges (if you only make it look a little different in a big way, it gives more of an eye popping effect)
then put a trans temp and oil temp in the A-pillar
Old Dec 27, 2009 | 12:22 AM
Cheat's Avatar
Cheat
I like the piller idea but i like this too.
http://www.glowshiftdirect.com/Unive...wivel-Pod.aspx
Nice set up.
Also I will just have to sit down with a card board templet of the cluster and look at it for a while. Plus it might not even work. Hope it does though.
Old Dec 27, 2009 | 12:27 AM
95MaroonMonster
would be sweet if it does
if you do it, take pics as you go and post a DIY for it
