Will this deep pan fit my truck
Old Dec 28, 2009 | 08:35 PM
PurplDodge's Avatar
PurplDodge
Originally Posted by 011500Ram
Buying a pan based on how it will take an impact is quite silly. Buy the pan with the specifications you need, and build around it. Use a skidplate.
Build a skidplate around this pan!!!!
BEEFY!
And finally installed:
Thats a Mag Hytec double deep pan. I stole these pics from aim4squirrels.
Old Dec 28, 2009 | 09:15 PM
BigRedRam95's Avatar
BigRedRam95
summit told me today that the pan will fit my trans and add 3QT
Old Dec 28, 2009 | 10:03 PM
dhvaughan's Avatar
dhvaughan
measure the depth of your existing pan and compare it to the actual depth of the new one. since you have a 95 with 46RH, it might add a little extra. the 96/97+ 46RE's with the electronic stuff had a much deeper pan as stock equipment than the old 727.
Most claims of extra capacity are compared to the 727, so the only way to cut through the BS is to measure the depth.
Old Dec 29, 2009 | 10:31 AM
babyhuey6810's Avatar
babyhuey6810
yeah,if the only thing you have to worry about is parking bumps I guess your right.Of course if you actually use the 4wd lever.....
Old Dec 29, 2009 | 11:23 AM
Miami_Son's Avatar
Miami_Son
I'm with you. I would much rather have a dented pan than a cracked one. And as low as that Mag pan hangs down the likelihood of it hitting something is way greater.
Old Dec 29, 2009 | 11:59 AM
PurplDodge's Avatar
PurplDodge
Dont start the 4WD ****.
Old Dec 29, 2009 | 12:38 PM
011500Ram's Avatar
011500Ram
BEEFY!
Easy. Get some tube, strap, and go for it.
Why do people on this forum find real fabrication so difficult? I guess if its not a spacer or a bolt on, its beyond most people here.
95MaroonMonster's Avatar
95MaroonMonster
yeah,if the only thing you have to worry about is parking bumps I guess your right.Of course if you actually use the fun lever.....
there fixed it for ya
Old Dec 29, 2009 | 09:07 PM
babyhuey6810
Aint got no problem wit fabritatin,boss,just hate to see people buy expensive parts that dont work mo betta than what they had just cause some web wheeler thinks its cool.Mag pans work great on big duallys,but not so good when poo-poo hits the rotary oscillator.Sorry I didnt know the F W D was a four letter word around here.My bad.
Old Dec 29, 2009 | 11:57 PM
PurplDodge's Avatar
PurplDodge
I'm not digging on fabrication, I wish more people did it on this forum. Plenum kits and spacer lifts on this forum get really boring. I'm gonna have my shop teacher help show me how to weld this spring, then I want to build some really cool stuff for the truck.
