Will this deep pan fit my truck
Hey guys does any one know if this pan will fit my 95 ram 1500 5.2? http://www.summitracing.com/parts/DER-14110/ Also does anyone know a good deep engine oil pan that will fit my truck
Yes, but it is the same depth as the stock one.
These Mag Hytec pans are great:
http://www.genosgarage.com/prodinfo....er=MH-727-9497
You sure about that?
Transmission Pan Material-Steel
Transmission Pan Finish-Zinc
Transmission Pan Style-Deep
Capacity Increase-3 qt.
Drain Plug Included-Yes
mag hytec pans look great,but they wont take an impact.I once had a catapillar 3126 with a cast pan that hit a really bad pothole and the pan crumbled.I replaced with a stamped steel pan off of a 3116.Hit the same hole and only had a crease in the pan.I was convinced that stamped steel pans are better and cheaper.
From the old 727 pans.
Installed one of those last spring along a filter. It took 11 qts. to fill it. (Warm & in neutral)
Trending Topics
Then again some people don't use them like trucks so I guess it depends :\
