i have an 01 dodge ram 1500 sport 5.9 motor, my truck started to eat oil, no smoke out of the pipe or leaks anywhere, but im 1.5 quarts down, gas milege is horrible, and between 2000 and 3000 rpms sounds like some rattle sound maybe valves not sure but the noise is only on hard acceleration and on low gears, when im accelerating calmly no knock, what can it be? and where should i start to look? can it be plenum gasket and can that cause for valves to knock?
the noise is deff coming from the motor but i cant figure out whats making noise, does anyone know if the plenum gasket is no good that causes a vacum leack if im correct, can that cause the valves to make a rattle noise?
