LSD Special Fluid
Old Jan 3, 2010 | 01:02 AM
redheadhunter21's Avatar
redheadhunter21
Default LSD Special Fluid
Ok my truck came with LSD from the factory its a 96', I got it from my dad and since I have been driving it, it will only lock up both tires every once in awhile(Drifting while turning left, in mud, and just noticed while powerbraking).
The question is does anyone make a differential fluid that promotes warn clutches to catch.
Just want a temporary fix that'll last untill I buy my locker
Old Jan 3, 2010 | 01:10 AM
offroadjosh's Avatar
offroadjosh
I am also interested about this =P
Old Jan 3, 2010 | 11:12 AM
Miami_Son's Avatar
Miami_Son
That's the way a limited slip is supposed to work. It isn't a locker or posi. Clutch actuation happens when one wheel starts to spin and exerts pressure on the clutch pack causing it to engage and apply traction to both wheels. Power braking can often accelerate this action.
Old Jan 3, 2010 | 12:59 PM
redheadhunter21
I understand what your saying but somedays it will take awhile for it to engage or not engage at all at first I thought it was completely shot, but the clutches are just warn
Old Jan 3, 2010 | 01:02 PM
Miami_Son's Avatar
Miami_Son
If the clutches are worn it will have trouble engaging and no fluid will fix that. Mine is still working great at 105k miles because I change the fluid every 20k and always use synthetics with the proper LSD additive.
Old Jan 3, 2010 | 04:00 PM
torp74's Avatar
torp74
Yep, got to make sure you use the friction modifier. You can pick it up at most any automotive store.
Old Jan 3, 2010 | 09:12 PM
redheadhunter21
Well I have to change the fluid soon anyways so maybe new fluid will be the trick, do you recommend any brands
Old Jan 3, 2010 | 09:17 PM
PurplDodge's Avatar
PurplDodge
75W-140 Synthetic. Valvoline or Mobil 1 can be bought at any parts store.
Old Jan 3, 2010 | 09:38 PM
johnjokela's Avatar
johnjokela
royal purple does'nt require additives, i havent had any probs with it, until i post this im sure... hahaha
Old Jan 3, 2010 | 10:13 PM
redheadhunter21
Yea I have to stop by autozone and get fluid and a gasket, its leaking thats why im even messing with it, hopefully no parts sitting in the bottom of differential
