Dual piston caliper
Old Jun 17, 2010 | 02:13 AM
  #51
J415's Avatar
J415
Originally Posted by matty675
... would i benefit from installing this master cylinder? the bore size on the 1500 and 3500 master cylinder are both 1 1/4"
The 2 are NOT interchangeable. The 3500 MC has a longer stroke length then the 1500.
Old Jun 17, 2010 | 11:04 AM
  #52
matty675's Avatar
matty675
the brake booster and line hook ups are the same... what would keep me from doing the swap?
Old Jun 17, 2010 | 11:07 AM
  #53
matty675's Avatar
matty675
Originally Posted by redheadhunter21
Yeah the LD 2500 is the same thickness as the 1500 rotor
Thats above my knowledge for the master cylinder as I do not know the differences between the 2 and I do not know about the rotors my truck is 2wd and I cant swap to newer rotors so maybe someone with more knowledge on this can help you
why wouldnt you be able to swap to newer rotors?
Old Jun 17, 2010 | 11:41 AM
  #54
J415's Avatar
J415
Like I said, the 3500 has a longer stoke length from the booster. I never said anything about them not being able to bolt on. But don't let me stop you from doing it.
Old Jun 17, 2010 | 01:00 PM
  #55
matty675's Avatar
matty675
i guess i dont quite understand, what do you mean they are not interchangeable? why wont it bolt on and improve my braking?
Old Jun 17, 2010 | 02:44 PM
  #56
redheadhunter21's Avatar
redheadhunter21
This DOES NOT affect 4x4's but for the 2wd truck in 00 they switch from a rotor that holds the bearings in it to a seperate hub unit and rotor so I would not be able to switch to newer rotors without changing spindles and a couple more things
I dont know if they newer rotors will fit for 4x4s that would be something you would have to go to a parts store to compare the 2
Old Jun 17, 2010 | 03:07 PM
  #57
J415's Avatar
J415
No they are NOT interchangeable. The 3500 has a longer stroke length from the booster. The 1500 has a shorter stroke length. So if you put a 3500 MC that requires a long stroke on a 1500 booster that has a shorter stroke, well lets just say that you won't be stopping any time soon. Your more then welcome to try it and prove me wrong.
Old Jun 17, 2010 | 05:02 PM
  #58
matty675's Avatar
matty675
sorry if im being difficult but i dont follow because as i said the boosters are the same for 1500 and 3500
Old Jun 17, 2010 | 06:45 PM
  #59
J415's Avatar
J415
Maybe you should read the FSM. That should clear up any questions you have.
Old Jun 17, 2010 | 06:52 PM
  #60
matty675's Avatar
matty675
Originally Posted by j415
maybe you should read the fsm. That should clear up any questions you have.
-------------------fsm?
