check gauges!!!
Old Jan 4, 2010 | 03:01 PM
surferguy12's Avatar
surferguy12
Default check gauges!!!
i got a 2001 dodge 1500 sport 4x4, my check guages light comes on and my oil pressure gauge goes to 0 then back up to 40 but doesnt move after that it stays frozen in place then the light turns off wat it is the problem? hooked it up at atuozone and no reading at all
Old Jan 4, 2010 | 03:04 PM
Relex's Avatar
Relex
Have you checked your oil level recently?
Old Jan 4, 2010 | 03:14 PM
surferguy12
did oil change 1500 miles ago and no leaking
Old Jan 4, 2010 | 03:28 PM
Relex's Avatar
Relex
The only reason why I asked was because my truck burns oil or I have a bad plenum gasket and I have to put oil in it sometimes. Well I didn't add any for awhile because I sorta forgot about it and I had the same problem you are having. Needless to say I was over 3 quarts low.
Old Jan 4, 2010 | 03:37 PM
Augiedoggy's Avatar
Augiedoggy
a lot can burn up in 1500 miles especially if your plenum gasket is leaking...
Old Jan 4, 2010 | 03:42 PM
Mowhawk's Avatar
Mowhawk
yep, check ur oil level
Old Jan 4, 2010 | 03:54 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
oil pressure sensor on its way out possibly......or bad dash guage.....or oil pick up tube issue
Old Jan 4, 2010 | 04:59 PM
quackaddict's Avatar
quackaddict
mine did that once right after I got it and it was low on oil, that or sender.
I have got to figure out how to turn mine of because I have aftermarket gauges so that is driving the dashboard crazy.
Old Jan 4, 2010 | 05:33 PM
95RAM360's Avatar
95RAM360
yea oil level since you said it stays at 40 after it drops, that because its takes like 43 seconds for regular oil to completly cycle through the whole motor, synthetic is like 30 seconds....(after its been sitting and the oil has settled)
^yes these are facts, i may be alittle off on the times though...
so check the level
Old Jan 4, 2010 | 06:28 PM
surferguy12
thanks guys went to autozone and added oil and it was almost bone dry, i dont know why it burned so much so quickly, what is a plenum gasket?
