Snapped the axle shaft need help!
Old Jan 5, 2010 | 08:10 PM
PurplDodge's Avatar
PurplDodge
Drum brake parts are cheap. I got new shoes, hardware, and 1 ton wheel cylinders for around $50. New drums are $44 from RockAuto.com
Old Jan 5, 2010 | 09:55 PM
dhvaughan's Avatar
dhvaughan
i'm not understanding the question. your axle shaft broke, and so you have a tire, a wheel, a brake drum, and the end piece of the axle shaft all laying on the ground.
from the junk yard, you've gotten either a complete rear end housing (with center diff, axle shafts, back plates, drums, etc) or you got an axle shaft only....
provided the parts are from the same chrysler 9.25 family, you can remove and interchange any pieces from one rear end housing to the other (including axle shafts, brake shoes, brake drums). the only thing you should not remove is the ring and pinion and carrier bearings, as these require a special setup.
Old Jan 5, 2010 | 10:24 PM
PurplDodge's Avatar
PurplDodge
When you snapped the shaft, did the end (of the shaft) come out with it?
Old Jan 6, 2010 | 06:30 AM
1998ram5.9's Avatar
1998ram5.9
yess the end of the shaft came out
Old Jan 6, 2010 | 06:34 AM
PurplDodge's Avatar
PurplDodge
Well, the c-clips probably are broken too.
Old Jan 6, 2010 | 07:27 AM
dhvaughan's Avatar
dhvaughan
wait a minute. how many ends of the shaft fell out?
the outer end only (with the lug nuts on the hub)
or the inner end (with the splines)?
i'd expect the inner end to still be stuck up inside the axle housing, still held in place by the c-clips.
Old Jan 6, 2010 | 08:40 AM
1998ram5.9's Avatar
1998ram5.9
the outer end is the one that broke off. The inner is still in there held by c clips. I havent taken the cover off yet but how hard is it to disconect the shaft from the inside?
