99 v10 choking problem..?
hi, im a newbe, i have a 99 2500 v10 auto that i got about 2 months ago, i noticed that somtimes during acceleration it with bog but more of a choking bog, like its hesitating when i let my foot up just a **** hair it will stop but when i put it down again it will do the same thin, sometimes ill will floor it to try and make it stop and it will take a few moments then clear out. it does this when cold and warm, but more often cold. anyone know what it is? possibly fuel filter i thought but hope not seeing how its in the freaking tank. any advice would be apreciated thank you.
ok, well its not plugs and not a vac leack, compression check turned out ok, then 3 days ago it started chuging and vibrating while on highway, started pumping bule white smoke out as i was driving, smelt really rich like fuel, puled plugs to see if they were fouled, as i was pulling them out one looked as if the piston smaked into it and broke the flint off, also looked some what melted, replaced it started it up ran ok for 2 seconds then did same thing, pulled plugs again and the same plug on the other side of the motor was broke in the same manner. any thoughts? thought was head gasket but cant imagine both going at same time, also dosnt explain the plug problem, unless i spun a bearing somhow and its throwing off how far my pistons are traveling.
it was quite loud, sounded like an old desiel farm tractor, and yes i did have the right plugs, also it was the 4th plug in from the front on the passenger side that broke first, then the same plug on the drivers side, plus the smoke was coming out both tail pipes before the second plug broke and its true duels so idk where the somke is coming from
Trending Topics
What plug are you running?
Champion QC9MC4 is what I have and it is the OEM recommended for the v-10
I tried another from auto zone and it ran like crap.
But like Miami said, it sound's like the plugs are suspect.
