problems with an electric fan conversion
Old Jan 7, 2010 | 01:37 PM
ztomtog2's Avatar
ztomtog2
If you buy a fan controller it comes with a relay built into it and a temp sensor that you jam into your rad. that way you dont have to contstanly watch your temp gauge and flip a switch everytime it heats up like some people do.
Old Jan 7, 2010 | 01:41 PM
J415's Avatar
J415
If you do buy a probe type temp sensor, an old trick for that is to wrap the probe in foil and stick it in the rad. That way you won't get a false reading with the wind interfering.
Old Jan 7, 2010 | 01:43 PM
dakotas ram's Avatar
dakotas ram
yeah, my controller is one from autozone and i have a relay, the fuseholder that melted was a small one. after that i ordered a maxi fuse holder........i believe the mark8 and the taurus fans are different
Old Jan 7, 2010 | 01:45 PM
dakotas ram
my probe is in the radiator hose
Old Jan 7, 2010 | 02:26 PM
ztomtog2's Avatar
ztomtog2
The foil trick is a good idea. ill do that to mine. my fuse holder also blew and i just replaced it with one from a tractor. My dad owns a tractor dealership so when i can use somethin i do. idk how many john deere parts are on my truck. lol.
Old Jan 7, 2010 | 10:40 PM
millertime 1321's Avatar
millertime 1321
i was thinkin that i wanted the thread in type that plugs into the intake by the thermostat, figured those are more accurate
Old Jan 7, 2010 | 11:17 PM
PurplDodge's Avatar
PurplDodge
You can also get ones with a thread in sensor.
Old Jan 7, 2010 | 11:40 PM
BigRedRam95's Avatar
BigRedRam95
all the guys with two speed fans how do you control the two speeds? and how do i tell if my fan is two speed?
Old Jan 7, 2010 | 11:59 PM
millertime 1321
im pretty sure the two speed is just two power chords and one ground. one power is for the high and one is for the low. they make two speed controllers. spal sell them as does summit.
Old Jan 8, 2010 | 12:24 AM
dakotas ram
the mark8 fan is a 2speed, but on mine and others ive read about, you have to have the electrics from the car b/c just swapping wires is the same speed
