A/C Clutch
Old Jan 6, 2010 | 04:54 PM
bvincent's Avatar
bvincent
Default A/C Clutch
How hard is it to change the A/C Clutch? Mine sounds like bearings are going bad. IT squeaks all the time. took the belt off to find which pulley was the culprit. the A/C pulley is culprit..... How hard is it to chnage or is it possible?
Old Jan 6, 2010 | 05:49 PM
halfamil's Avatar
halfamil
https://dodgeforum.com/forum/2nd-gen...placement.html Work on this,until I can find something else.
Old Jan 6, 2010 | 06:01 PM
97black_ram's Avatar
97black_ram
Well just a thought, but if its cold out you could just get a smaller belt and bypass the A/C if you wanted to do that.
Old Jan 6, 2010 | 06:05 PM
011500Ram's Avatar
011500Ram
What about the Defroster then?
Old Jan 6, 2010 | 06:08 PM
97black_ram
the defroster will work like normal. All the A/C does is remove moister from the hot air.
Old Jan 6, 2010 | 06:25 PM
011500Ram's Avatar
011500Ram
Seems like a crucially important detail?
Old Jan 6, 2010 | 07:50 PM
97black_ram
I'm just saying it can't be that important cause trucks with no A/C don't have any problems with their defrosters.
Old Jan 6, 2010 | 08:37 PM
halfamil's Avatar
halfamil
The reason the compressor comes on with the defroster is to lubricate the a/c components in the winter months.Then when that first time you turn it on in the late spring,it will work,and not be seized up.
