Idle drops and almost dies
Old Jan 7, 2010 | 03:02 PM
jtlyons06's Avatar
jtlyons06
Question Idle drops and almost dies
I have a 94 Ram 4x4, 5.9L gas, auto, and it has developed an issue that I am not familiar with. It starts up and runs normal, but when I get to a stop sign or come to a stop in gear with the break on it idles really low like its gonna die and the gauges go to zero and check engine light comes on. If I take off or put it in neutral and rev it it runs normal, but check engine light stays on. Thank you.
Old Jan 7, 2010 | 03:13 PM
pricja00's Avatar
pricja00
sounds like a dirty throttle body...
Old Jan 7, 2010 | 03:18 PM
jtlyons06's Avatar
jtlyons06
I cleaned it with gumout TB cleaner spray following the directions on the can. But it still was doing the same thing. It did was dirty and a little sooty black. It is clean now and silver.
Old Jan 7, 2010 | 03:27 PM
pricja00's Avatar
pricja00
until a better answer comes along, I'd give it another shot. My V10 was doing the same thing, I wiped the inside of the throttle body as far past the butterfly valve as I could reach and then had a friend nurse the throttle while I emptied the rest of the can in there. Cured my issue.
Old Jan 7, 2010 | 05:22 PM
95RAM360's Avatar
95RAM360
if theres black on the butterflies, your plenums blown....
Old Jan 7, 2010 | 05:28 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
idle speed control motor...mayby try this link. do a forum search there are dozens having the same problem
https://dodgeforum.com/forum/3rd-gen...shuts-off.html
Old Jan 12, 2010 | 01:54 AM
jtlyons06's Avatar
jtlyons06
I cleaned the T.B. taking more time and care this time. On the first drive since doing so it seems better. Thank you for your answers. I did have the check engine light come on as I pulled back into the driveway. I will look into that.
Old Jan 12, 2010 | 02:08 AM
halfamil's Avatar
halfamil
When you get a chance, click on the user cp at the top of the page and fill out your truck info. and signature. You will get many more replys to a question.
Old Jan 12, 2010 | 06:01 AM
95RAM360's Avatar
95RAM360
camshatf position sensor? ive read a few threads with this problem in the past few days, and turned out to be a loose/bad camshaft position sensor
