Project "Swamp Fox"
Old Jan 12, 2010 | 06:05 PM
  #21
dodge15004x45.9's Avatar
dodge15004x45.9
^ Nah I don't need a stock one I need one like you have. But I will take some of that budget since you are offering.
Old Jan 14, 2010 | 09:47 PM
  #22
quackaddict's Avatar
quackaddict
Ok haven't gotten to mess with the truck in several days but did get to do the on-off key code checker thing. Pulling 2 codes P0113 and P0118 they are both high voltage codes one for IAT and one for ECT. Any ideas on these I don't know what causes these codes.
Old Jan 14, 2010 | 09:49 PM
  #23
BlueBeast2's Avatar
BlueBeast2
stupid question but is the IAT plugged in? I got that code cause mine was unplugged
Old Jan 14, 2010 | 10:15 PM
  #24
quackaddict
In my haste to get my codes I did a quick search I only have internet on my phone at home modem issue, anyway the ECT (coolant temp) is not plugged in because I have aftermarket guage sender in it's place which is also causing a check guages light. The IAT is plugged in but I am having a stalling issue maybe related. What is also curious is my oil pressure sender connection is unplugged again because of aftermarket gauge but not code for it.
Old Jan 14, 2010 | 11:09 PM
  #25
rideordie's Avatar
rideordie
This is awesome. Nice to see that you've devoted it to your dad, and that you can make one kick-*** truck!
Good luck! Hopefully some of us can help you out along the way.
Old Jan 20, 2010 | 05:50 PM
  #26
quackaddict
Quick update:
Purchased a new IAC Sensor and TPS sensor and gonna clean the throttle body just a little insurance to keep the motor well.
Also got my 180* T-Stat as well as time to drain the break-in oil. I got a heck of a deal I think 5 Quarts of Mobil-1 Extended Perf and Extended Perf. oil filter (got the bigger one) for $34 (oil filter was $12 by itself had I done it seperatly.)
I am going to do my Leveling Kit this weekend, to anyone who has done one. I put one on an F-250 a year or so ago and it made the front actually taller than the front. On our trucks do the leveling kits acutally level or will I get a little "prerunner" look?
Old Jan 20, 2010 | 05:53 PM
  #27
yakkier's Avatar
yakkier
The Prerunner look, looks nice on mid 90's chevys but looks like crap on ours, and from what iv seen i dont think it does
Old Jan 20, 2010 | 10:50 PM
  #28
quackaddict
Bout at the end of my rope. Both sensors replaced still giving me a problem starting. Replaced T-stat still overheating. The oil pressure didn't drop below 44 which is an improvement. Should the metal piece inside radiator cap be loose when it is off? How can I tell if radiator is bad? Also I noticed when the engine is off the fan is hard to turn by hand which I found odd. Just tired of spending 100 bucks and 2 hours and getting nowhere.
Old Jan 20, 2010 | 11:03 PM
  #29
BlueBeast2's Avatar
BlueBeast2
I think the fan being hard to move is normal
Old Jan 21, 2010 | 04:04 AM
  #30
99DRAM31887's Avatar
99DRAM31887
yea the fan being hard to turn is normal. That means ur Clutch fan is still good not if it just spins its time for a new one
