Fuel injector plastic tips
Old Jan 8, 2010 | 04:26 PM
jhamilton19's Avatar
jhamilton19
Default Fuel injector plastic tips
hey, i just noticed that 4 of my fuel injectors are missing the plastic tips on the lower ends of the injectors. i found a couple of them in pieces. can these be found any where? i know the snap on and off but i need to buy some new ones. im getting the o-rings from the parts store but i cant find the little plastic tips that are supposed to be there. any one got a few or know where i can get some without getting raped? thanks.
Old Jan 8, 2010 | 07:44 PM
jasonw's Avatar
jasonw
Site Moderator
Can you provide a picture? I replaced an injector last year that was giving me weird readings when I tested it, and I don't recall anything about tips.
Old Jan 8, 2010 | 09:36 PM
jhamilton19
here are some pics.
Old Jan 8, 2010 | 09:44 PM
jhamilton19
i dont know why they are so big, but there they are.
Old Jan 8, 2010 | 09:51 PM
jasonw's Avatar
jasonw
Site Moderator
Wow, I didn't even know they had tips that came off.
I doubt you can find just the tips. Sorry I'm not of much help. Hopefully someone else here can chime in.
Old Jan 8, 2010 | 09:58 PM
jhamilton19
ive called all the parts stores. no luck. i tried to call some dealers but they were all closed. its friday. i wonder if i can get by without them. id like another few opinions first though. thanks.
Old Jan 8, 2010 | 10:36 PM
cmckenna's Avatar
cmckenna
Those are not supposed to come off. Those are there to protect the nozzle. You'll have to contact a person who rebuilds injectors to get those tips.
Call Rob Stark www.robstark.com to see about replacing those. Also, your going to want to double check your O-rings very carefully to ensure that they are not undersized. It is not uncommon to find them undersized and end up with leakers.
CM
Old Jan 8, 2010 | 11:09 PM
jhamilton19
cool, thanks for the web site. i have found replacement o-ring kits every where. im going to get some and replace them for sure. i will see if this guy can help me out. hope he can. i dont want tp buy new ones. thanks again.
Old Jan 9, 2010 | 12:25 AM
dakotas ram's Avatar
dakotas ram
witchhunter.com
Old Jan 9, 2010 | 12:29 AM
cmckenna's Avatar
cmckenna
Rob is the best in the industry and a friend of mine out here in So Cal. He's the No 1 guy that most of So Cal including myself uses to rebuild injectors, clean injectors, test them etc etc.
All you need to do is to provide him with a number off the injector as to which model injector you've got. Then, from there, he can source the appropriate caps.
Get your o-rings from him as well. See if he's got enough in stock to do the whole set. His work, the ones that come with injectors don't. At least, twice in my experience, they did not.
On one set, they were >15 mils out of tolerance and, on another, they were too hard thus not making a good seal.
