How do I get the headlights out?! (pic)
Old Jan 9, 2010 | 12:25 AM
dakotas ram's Avatar
dakotas ram
i had to squeeze mine in and out......ended up chipping my paint on the top
Old Jan 9, 2010 | 03:13 AM
bobboraze's Avatar
bobboraze
Yeah these were an absolute bitch to get in and out. Definitely scratched up some paint...
Look great though now all of a sudden my left signal(orange light) bulb is acting up...
When left signaling the indicator blinks really fast, and the front left bulb doesn't light up. Nor does it light up when hazards are activated.
The right side all works as it should.
After searching through old threads I've found that this indicates a bulb is out, or relay issue. Well I don't believe the bulb is out as it lights up fine with the running lights. Only signaling/hazards causes it not to work...
I suppose I'll go out tomorrow and look at the relays? Why would this happen all of a sudden?
edit as to not bump:: Yes it was indeed the bulb, what threw me for a loop was that I didn't realize they had 2 filaments inside. The parking coil was fine yet the blinking coil went out.
Thanks!
Old Jan 9, 2010 | 03:37 AM
dakotas ram
maybe not plugged in all the way or its out from moving it around
Old Jan 9, 2010 | 12:35 PM
Sheriff420's Avatar
Sheriff420
an unplugged or burned out bulb will give you the rapid blinker on the dash.
Old Jan 9, 2010 | 02:08 PM
Augiedoggy's Avatar
Augiedoggy
yep burned out or uplugged...its tough to tell by looking at them i8f they are bad too...
Old Jan 9, 2010 | 03:41 PM
Sheriff420's Avatar
Sheriff420
yep, my driver bulb looked fine at a glance and the blinking coil in it worked but the parking coil didn't.
