1999 Ram acts like fuel pump is out
Old Jan 10, 2010 | 07:58 PM
halfamil's Avatar
halfamil
Originally Posted by 95RAM360
^so that fixed it?
I guess it just fixed one symptom man.Then he put a new ECM in it lol. I was only able to make couple post lastnight. Could you tell I was about drunk?
Old Jan 18, 2010 | 11:23 PM
Robertb6963's Avatar
Robertb6963
I am in the middle of a engine swap so I figured that the CPS would be much easier to replace once the engine was out but I will follow up on the progress.
Old Jan 19, 2010 | 02:24 AM
halfamil's Avatar
halfamil
That would be great Robert6963, If it is the CPS that would be a good tip for someone else, down the road. Hang in there man!!!
Old Jan 25, 2010 | 07:35 PM
Roger32327's Avatar
Roger32327
My truck is doing the same thing. idles from 400rpm to about 1200 rpm. A cam position sensor could be causing this. I has a shop put it on a computer and I get a code saying that the TPS voltage is too high. I replace the TPS and still have the code and bad idle. Any help???
Old Jan 25, 2010 | 09:17 PM
dhvaughan's Avatar
dhvaughan
did you reset the pcm when you replaced the TPS. if not, try that.
Old Jan 25, 2010 | 09:21 PM
Roger32327's Avatar
Roger32327
How do you reset the PCM? I did disconnect the battery for about 30 minutes
Old Jan 25, 2010 | 10:05 PM
dhvaughan's Avatar
dhvaughan
disconnect negative battery cable and turn on headlights for 30 seconds to drain the memory in the pcm.
Old Jan 26, 2010 | 10:18 PM
woodcrafter0392's Avatar
woodcrafter0392
Default same code 24 other problems
I have a 91 B250 Conversion Van with a 5.2 (318) and I have the code 24 which is TPS over or under voltage. The van idles great but sometimes when you try to accelerate hard it studders and dies or just studders on restart it will take off with no problem anyone hade this problem. Replaced fuel filter, coil and sparl plugs runs a little better but same studder problem/ I can hear fuel pump running at idle from under car and also put stephiscope on injecters seem to be OK. Any other ideals out there
