What have you replaced since.....
Old Jan 11, 2010 | 11:08 AM
Gnarkill666's Avatar
Gnarkill666
um bought the truck march 2003, transmission reuild from a cross country move and a craked dash. about to replace all bushings from running boggers for the last 3 years and replace heim joints on the skyjacker lift with currie joints. most of my original suspension parts replaced from the lift are still in use on my step bro's old truck he fixed after totaling it for the 3rd or 4th time.
Old Jan 11, 2010 | 12:22 PM
Laramie1997's Avatar
Laramie1997
Plenum
Various spark plugs/ wires/ dizzy's
Transmission
Rear differential
Numerous Head light housings
Head light bulbs
Center console- Granddad left a spot light turned on, and pointed down on the seat.
Rear bumper
Head unit
Front speakers
Rear speakers
Alternator- Just for a beefed up one
Too many batteries to count
A couple of windshields
One rear glass
One Driver's side glass
Couple of Tail lights
Top cover for the front bumper
Couple of Grilles
Numerous fog lights
A hood
Tint
Tires
Shocks
Ball joints
Tie rod
couple of rotor sets
Numerous brake pads and shoes
I think that's it for right now....
Old Jan 11, 2010 | 12:38 PM
95RAM360's Avatar
95RAM360
Bought 8/3/2009
10K BEFORE I BOUGHT IT (recipts from PO)
-tranny beefed up/rebuilt
-4.10 gears in front and rear
-Dealer fuel pump
-Radiator
IVE REPLACED
-All Shocks
-Shackles
-Water pump
-Fan Clutch
-Thermostat
-Fluid changes for front/rear diff, transfer case and tranny
-switched to synthetic
-Port and Polished modded intake Manifold
-had fuel injectors cleaned
-Ball joints
-Hughes Plenum/Intake Gaskets
-PCV Valve and Breather
-Valve Cover Gaskets
-Mopar Champion Copper Plugs
-MSD 8.5 mm wires
-ACCEL Dist. cap/rotor and coil
-Timing Cover gasket
-Belt
-Front pads and rotors
-rear pads/ hardware
-parking brake
im most likly missing a few thing...
Old Jan 11, 2010 | 10:49 PM
AmericanPower's Avatar
AmericanPower
Since summer 09
I've replaced
All tie-rod ends
Drag link, sleeves
Both right ball joints
Both front wheels bearings
Steering stabilizer
Wiper linkage
Wiper motor
Rear axle
1 ton wheel cylinder
Rear drums, pads
Both rear Wheel bearingsw
All speakers except tweeters
To do :
Shocks
Alignment
Rust
Complete tune-up
Ect....
Old Jan 11, 2010 | 10:54 PM
mr freeze's Avatar
mr freeze
Jinx thread if I ever saw one.Im staying clear of this one.
Old Jan 11, 2010 | 11:13 PM
xskylinedx's Avatar
xskylinedx
lets see....... my list in no particular order:
Rear axle U-joints, rear limited slip, shocks, front wheel bearings; 2 left 1 right, rear drums,
front rotors, bumper, hood, left front fender, right front fender, grill, both right side doors,
right side mirror, timing chain, water pump, tps, coolant sensor, t-stat, map sensor, IAC,
steering stabilizer 4 times, plenum, and transmission.
I think thats it, but my memory kinda sucks.
Old Jan 11, 2010 | 11:26 PM
PurplDodge's Avatar
PurplDodge
Since 2004 (That was almost 60,000 miles ago) we've replaced:
2 transmissions
Front Axle
Sway bar
Trac bar
Plenty of synthetic oil changes
K&N FIPK
14x3 AC
Water pump
Shocks
2 sets of crappy tires
Tune ups
Brake rotors, pads, hoses
Drums, shoes, springs, wheel cylinders
That might be it...
Old Jan 11, 2010 | 11:43 PM
BlueBeast2's Avatar
BlueBeast2
Why is it my thread?? lol
Lets see...
tires
LSD
gears
cap,rotor, plugs, wires
rebuilt engine (almost everything new)
brakes
front rotors
exhaust
had tranny work done
new evap lines
think thats about it
Old Jan 12, 2010 | 12:28 AM
RamSport97's Avatar
RamSport97
Bought my ram off my brother in 06 with 80 thousand on the ticker
-Battery
-Alternator
-Water Pump
-Plugs
-Hughes plenum fix
-New muffler and cat
-Tires
-Brake shoes
-New Bilstein shocks
And a few body repairs but thats not the pickups fault.
Old Jan 12, 2010 | 12:31 AM
dodge15004x45.9's Avatar
dodge15004x45.9
shocks
tires
hubs
tie rod
tie rod collar
coil spring
leafs
ball joints
axle u joints
axle seals
breaks
black boxes on the side of the truck
oil pan
tranny pan
sway bar end links
o2's
spark plugs
tint
needs new y pipe and bumpers and gears.
