Do you loose any oil between oil changes?
Old Jan 13, 2010 | 09:09 PM
  #21
DODGEIT105's Avatar
DODGEIT105
165,000+ on an 01' 4x4QC 5.9 and it uses about a quart between oil changes. I don't believe it is burning it since the exhaust looks fairly clean an dry. I do have valve cover leaks so I believe it is seeping out there. I change my oil every 7000 so if I add a quart between oil changes it is not so bad.
Old Jan 13, 2010 | 09:58 PM
  #22
95RAM360's Avatar
95RAM360
^you i believe have have plenum leak
Old Jan 13, 2010 | 10:38 PM
  #23
gonehuntin817's Avatar
gonehuntin817
damn, i burn a quart every 2 weeks
Old Jan 13, 2010 | 11:03 PM
  #24
PurplDodge's Avatar
PurplDodge
Originally Posted by 95RAM360
ok i just wanted to ask this to reassure myself...
ok i checked my oil today, and its about a 1/4 in above the add mark...i need an oil change in 400 miles...but i wanted to know if its typical for these to burn oil?
i check my oil once a week, or once every other week, and i checked it about 900 miles ago and its was pretty much to the max line...
My plenum is obvously not leaking..i looked inside, and since my intake is ported and polished its easy to tell...well the inside is still pure silver...the hughes plate was actually shining when the light hit it...
Valve cover gaskets i replaced 5K ago...i retorqued on my last oil change 2600 miles ago...theres no wetnesss or any leaks here...
Oil pan is completely dry all the way around so thats not it.
Oil filter is dry all the way arond, so thats not it.
and the oil dipstick isnt leaking where it enters the block...
so is it typical for these to burn oil when your near due for an oil change?
i used Quaker full synthetic truck and SUV 10w30 with a mopar filter.
A truck with almost 200,000 miles is going to burn a little oil over 3,000 miles. It is totally normal due to normal wear and tear. Valve guides are a little worn, and so are the piston rings. Its really nothing to worry about, your truck could probably go another 100,000 miles before you would need to re-build the short block. Just keep oil in it.
Old Jan 13, 2010 | 11:04 PM
  #25
halfamil's Avatar
halfamil
1 qt. between changes is very minimal for any vehicle with 75000 miles or more.Instead of adding a qt. just change it. There........just saved you $3.00 on an oil change!!!
Old Jan 13, 2010 | 11:11 PM
  #26
95RAM360's Avatar
95RAM360
well i got a quart oil oil today...and the kind i get is 6.49 a quart....geez prices now a days
but theres a for sure definate leak where the block meets the head, very very small though, just a part in the corner
Old Jan 13, 2010 | 11:22 PM
  #27
halfamil's Avatar
halfamil
Are you sure it's not coming from the back of the keg. Take a photo.The oil I use is $17 for 5 qts.and was $12 when I started using it in 2003.
Old Jan 13, 2010 | 11:24 PM
  #28
95RAM360's Avatar
95RAM360
its not from the keg, i can see exacally where its leaking.
im testing oils right now, i had Mobil 1 full syn, and was gettin 40 psi idle, and 45 -50 running.
Now im using Quaker Torque Full Sy 10w 30 and getting 45 PSI idle and 60 running.
but next im trying amsoil.
Old Jan 13, 2010 | 11:52 PM
  #29
halfamil's Avatar
halfamil
Wal-Mart SuperTech 10W 30 Full synthetic. My engine is living proof it works!!
Old Jan 13, 2010 | 11:58 PM
  #30
halfamil's Avatar
halfamil
If it has the API seal on the bottle it's all good, if you change it often.I
