emblem removal failure lol
Old Jan 14, 2010 | 03:41 PM
lord0fsal3m's Avatar
lord0fsal3m
Default emblem removal failure lol
well i removed my pass emblems a while back, finally felt like doing the front and when i took off the ram 1500 the adhesive on the "5" didnt stick, at first i was happy thinking i didnt have to heat a scrape that piece off, then i realized all the water and dirt building up in there made a bubble in the paint...
any suggestions?
Old Jan 14, 2010 | 03:49 PM
Augiedoggy's Avatar
Augiedoggy
sand /repaint and clear whole bottom of door (or whole door for better results) let it cure and try to blend with buffer.... rattlecan paint will work but be sure to let it cure for a couple weeks before buffing with very fine compound..
Old Jan 14, 2010 | 03:51 PM
dsertdog56's Avatar
dsertdog56
+1 on that. I did my 1/4 panel this fall and it came out much nicer than I expected.
Make sure you wash the area clean and use a wax/grease remover before sanding.
Old Jan 14, 2010 | 03:54 PM
dhvaughan's Avatar
dhvaughan
stick it back on ?
Old Jan 14, 2010 | 03:56 PM
Augiedoggy's Avatar
Augiedoggy
lol I was gonna say that too.... you could always upgrade to the newer flashier ram emblems like I did ...they cover more too... or throw a decal there with engine size or something...if you dont seal it though it will spread and rust most primer is not waterproof
Old Jan 14, 2010 | 04:01 PM
RamSport97's Avatar
RamSport97
Same thing happened to me when I removed the V8 magnum eblem on the passenger side. Ended up sticking it back on with construction adhesive lol.
Old Jan 14, 2010 | 04:20 PM
lord0fsal3m
well i have touch up paint, i wetsanded it and put a light coat on, hopefully its nice again tomorrow and i can put a few more coats on and then sand it smooth and put some clear on, if it looks like crap ill have to cover it up or something
Old Jan 14, 2010 | 05:34 PM
lord0fsal3m
id like to put this over it but i cant afford it lol
http://cgi.ebay.com/ebaymotors/MOPAR...Q5fAccessories
Old Jan 14, 2010 | 10:05 PM
BlueBeast2's Avatar
BlueBeast2
Them MFer's are crazy
Old Jan 15, 2010 | 03:34 AM
dakotas ram's Avatar
dakotas ram
you should feel lucky, when i removed the molding from my drivers side in fromt of the rear tire it ripped off a big chunk of bondo
