Intermittent Stalling/Surging Issues
Old Jan 31, 2010 | 09:09 AM
  #71
mnewbolds's Avatar
mnewbolds
Originally Posted by cmckenna
Trans temperature sensor voltage low
Is there a DIY somewhere that mentions it? I can't seem to find anything on it. I'll keep looking but I need to get it done yesterday. Any help would be appreciated. Thanks
Old Jan 31, 2010 | 09:38 AM
  #72
cmckenna's Avatar
cmckenna
Depending on what OBD you have, it also could mean: Torque converter clutch solenoid CKT is out of range.
This applies to OBDI up to 97 models that were OBDI 94-97.
I don't know what's in the DIY on here.
Good luck,
CM
Old Jan 31, 2010 | 10:21 AM
  #73
Sheriff420's Avatar
Sheriff420
Originally Posted by nonlinearedits
I bought a BWD as well.. it sounds like my truck has a blower now?! the air noise i loud as hell, it's more of a whistle... is that how its supposed to sound? The stock one was dirty as hell and the plunger fell out of it when i took it off...
do you have a gasket between the throttle body and the air box? and did you put the o ring (or gasket) on the IAC? also, did you clean out the hole that the pintle plugs? q tips and carb cleaner work good for cleaning that out.
It was not an "immediate" code. What I mean is the CEL did not come on, It just came up when I checked the codes. I do not think it was a code 32. It was something about a short in the egr circuit. Can't think of the number but I know it was just the plug on the egr valve.
UPDATE!-- Hughes Plenum is done and truck runs like a rabbit from a combine! New IAC. (Tip-- DO NOT TOUCH IT! IT'LL COST YOU!) and about 4ft. Of replacement vacuum lines. Not to mention- cat delete, radiator, hoses, fan clutch, t-stat, fuel injectors, plug wires, cap and rotor, e-3 plugs, and some other misc wallet demons. Thank God.
it's too cold to be that busy working on the truck.
Old Jan 31, 2010 | 11:00 AM
  #74
JohnnyRebs360's Avatar
JohnnyRebs360
If you have an automatic transmission, your truck's lock-up convertor may not be unlocking.
Old Jan 31, 2010 | 11:04 AM
  #75
mnewbolds's Avatar
mnewbolds
That's why I have a heater in the garage.
Old Jan 31, 2010 | 11:05 AM
  #76
Sheriff420's Avatar
Sheriff420
just rub it in why don't ya.
  #77
mnewbolds's Avatar
mnewbolds
Yes, I have an automatic. Is there a way to test for this without removing the trans? Also, where is the Torque converter control solenoid, and the Trans temp sensor?
Old Jan 31, 2010 | 12:01 PM
  #78
JohnnyRebs360
I know at the dealership they hook up a scan tool, lock it up and it kills the motor.
I know that the soleniod and temp sensor is inside the tranny, I think on the valve body. A good place to check would be a Hanes manual.
Old Jan 31, 2010 | 12:10 PM
  #79
mnewbolds's Avatar
mnewbolds
That's what I was hoping it WASN'T. Internal... I hate dealerships...
Old Jan 31, 2010 | 08:21 PM
  #80
cmckenna's Avatar
cmckenna
Ain't that the truth for sure. I had to simply change out a headlight on the driver side and man, I had a difficult time due to the cold. It was 13 degrees out and the wind was whipping like mad. So Cal spoiled me. I come out here (near NY) and, walking around is fine but, man, working on the truck when it's that cold- forget it.
