Blinker electrical problem. Need a little help
Old Jan 16, 2010 | 09:35 PM
charlie1935's Avatar
charlie1935
Originally Posted by cummins24421
every 3k miles....
I installed a bigger tank with a pressure cap and use synthetic fluid, never have to change it!
Old Jan 16, 2010 | 10:16 PM
cummins24421's Avatar
cummins24421
Originally Posted by 95RAM360
try this first...
i had the same problem except i had some added problems and it all turned out to be a ground wire at the rear of the truck,
there was a bad ground in the utility body (it has a knapheide service body) but i fixed that. maybe that ground wire being disconnected for so long screwed up the multi switch?
Edit: how the hell do you get that switch out?
Old Jan 16, 2010 | 11:08 PM
BlueBeast2's Avatar
BlueBeast2
umm theres a screw or 2 on the under side of the column you take the plastic off and theres 2 torx screws that hold it in
Old Jan 16, 2010 | 11:13 PM
95RAM360's Avatar
95RAM360
its a special torque set that you'll need for the bolts...
Old Jan 17, 2010 | 12:19 AM
cummins24421
yea its a keyed screw. regular torx with a pin in the center.
Old Jan 17, 2010 | 12:25 AM
BlueBeast2's Avatar
BlueBeast2
oh I forgot it had the pin sorry. Most of the ones i have found with the pin hole is the bit type kits
Old Jan 17, 2010 | 12:29 AM
95MaroonMonster's Avatar
95MaroonMonster
why a pressure cap??
evaporation protection...hey it happened to mine
crazzywolfie's Avatar
crazzywolfie
it is a security torques bit.
Old Jan 17, 2010 | 06:46 AM
95RAM360's Avatar
95RAM360
watch for leaks when switching to synthetic.....this could be your problem lol. you've lost out on blinks cuz you lost the fluid. try a quart of Lucus Blinker additive...works great.
mine was a ground at the very rear. when following the harness from the drivers side tail light, i came to a connector, and the ground wire had broken off right where it enters the clip, so i by-passed it, re- wired and all is well.
Old Jan 17, 2010 | 09:19 AM
BlueBeast2's Avatar
BlueBeast2
It's spelled torx. They spell it different for them http://www.google.com/m/url?cd=6&channel=gp1&client=ms-android-tmobile-us&ct=res&ei=0xtTS9C4HIrDtgfun4SFAw&og=gp&oi=blend ed&q=http%3A%2F%2Fwww.amazon.com%2FSMALL-SCREWDRIVER-SECURITY-TAMPER-PROOF%2Fdp%2FB000FIXXBA&resnum=6&sa=X&source=gp&ui pref=6&ved=0CP___________wEQ____________ATAG&usg=A FQjCNESuO-vpSX9LrNQHgOoplDCmNIKEw
