transmission slow to shift out of second
2001 dodge ram 1500 4x4 5.2 160,000 miles
This just started this morning. The truck has been driving fine, drove it last night and it was fine. This morning i get in crank up and drive off and the transmission takes forever to shift into second. The rpm goes up to 3000 and you have to be going about 30 mph for it to change to second. Other gears work fine. I read on other post it could be governor pressure sensor, solenoid, or tps among other things. What does everybody else think? I know where the tps is, but where is the governor pressure sensor and solenoid? how much are they and how hard are they to replace? Thanks in advance for the advice!
went to autozone. no codes were showing. I went ahead and got a tps and maybe I will have a chance to put it on tonight. I guess after 160000 miles it could use one. if it does not fix it then I will take to my trusted transmission guy. What is involved in adjusting the bands? Is there any harm in driving it untill I get it fixed? Thanks.
That's a good idea if it's someone you know and trust. Small problems on these transmissions left unattended can lead to big bucks. I'm sure you have checked the fluid in the correct manner, if not look in your owner's manual and go by the steps to check it. Also inspect your fluid on the dipstick. Dark color or burnt smell can tell you alot.
fluid is bright red and full. I bought this truck about a year ago to have a truck around the house. It supposedly had a rebuilt transmission. I hope it is something simple like band adjustment or governor pressure sensor or solenoid. I think life would be more simple and muss less frustrating if vehicles had no computers and they all had standard transmissions.
Trending Topics
DO NOT ADJUST THE BANDS!!!!!
All you need to do is adjust your throttle valve cable, it needs to be longer. I would bet 99% odds that is what it is. If you cant adjust it on the top of the engine then all you need to do is bend the L bracket that the cable mounts to on the transmission towards the engine about an 1/4 of an inch.
Do this before you replace the shift or pressure solenoids!
I agree to adjust the throttle cable, don't agree about bending a bracket to do it.
There is a little push lock tab on the adjuster, push it in [using a blunt tip like a phillips screwdriver] and adjust it one "click" either way.
If the shifting gets better, you might try 1 more click in the same direction.
If it got worse, then take it back to where it was, then go another click further the other way.
You can't actually hear it click, but you can feel it.
Can also use a marker to mark the cables current position on both sides of the bracket.
Very small adjustments can have a big effect, so take it slow.
