locker or spool?
Old Jan 17, 2010 | 05:13 PM
  #31
PurplDodge's Avatar
PurplDodge
Yeah, but when you are in 4WD it is going to be hell to turn.
Old Jan 17, 2010 | 05:20 PM
  #32
codyselcamino's Avatar
codyselcamino
does the disconnect, disconnect both tires or just one? i might be interested in one if it does both, one tire would make a difference but both would be awsome, if it only disconnects one a spool would put alot of stress on the cv joint still enguaged, did you look at the Lock Right lockers? im kinda in the same situation and im seriously considering one in my front end
Old Jan 17, 2010 | 05:33 PM
  #33
Hahns5.2's Avatar
Hahns5.2
Originally Posted by dodgeboy7
Anyway back to the whole reson why i start the thread. How is the spool going to put any more stree on the front end vs a locker or open end b/c either way the driver side u joint is spinning. I can under stand that it well be hard on the truck if i was on dry pavement but i am smarter then that.
As I said before, when you're using 4x4, the spool will store up energy in the shafts, a locker unlocks everytime you let off the gas, releasing that energy.
I've driven my B2 in the snow, it has lockers front and rear, it handles great and has no problems steering.
If you're going to have 1 locker, start with the rear.
Old Jan 17, 2010 | 05:35 PM
  #34
97ram5.2's Avatar
97ram5.2
i no u stated before that your not putting one in the rear but wouldnt a spool eat ur tires up realy bad realy quick always being engaged
Old Jan 17, 2010 | 06:55 PM
  #35
dodgeboy7's Avatar
dodgeboy7
That why you dont put it in 4wd when your on dry pavment. Kinda though that was com sen but i guess not.
  #36
dodgeboy7's Avatar
dodgeboy7
Only on the passager side
Old Jan 17, 2010 | 06:57 PM
  #37
yakkier's Avatar
yakkier
Thumbs up
LMAO thats awesome.
Old Jan 17, 2010 | 07:02 PM
  #38
dodgeboy7's Avatar
dodgeboy7
The locker going to store energy to and only unload when one feels that one tire going slow or faster then the other(when your turning) a spool is just going to make the tire slip to release the energy that why you only use off road
Old Jan 17, 2010 | 08:19 PM
  #39
PurplDodge's Avatar
PurplDodge
What idiot uses low range on pavement?
Old Jan 17, 2010 | 09:03 PM
  #40
olyelr's Avatar
olyelr
In my opinion, a Dana44 is way to weak of an axle to put a spool in... at least under a full size truck. And even when only using it off road, I still guarantee very difficult steering, and a very good chance of lots of broken axle shafts. Hell, the u-joints cant live with an open diff.
If you are dead set on a locker, I would seriously look into the Aussie locker. Its cheap (under $250), is 100% locking under throttle, yet still allows some differential when turning.
