'99 ram starting problem starter? solenoid? please help
Old Sep 19, 2023 | 05:50 AM
Follow the circuit for the starter relay control. Pretty sure the ignition switch provides power, and then the p/n switch sends it off to ground somewhere.
Old Sep 20, 2023 | 04:17 PM
woodtrimmer's Avatar
woodtrimmer
Hey "You ,
Thanx for the suggestion and will trace it there. Also another symptom that didnt register over the past few months that came to mind here. Everytime I turned the engine off, I would hear a "buzz" under the dash and only during shut down. Got an inkling on that one?
Old Sep 21, 2023 | 06:16 AM
I am not sure what is under there that would buzz..... Key buzzer? You don't have the electronic blend door.....
Old Sep 21, 2023 | 08:34 PM
woodtrimmer
Its got me baffled to and its sounds like relay maybe, but definitelty not the key buzzer,as its a lower pitch. I do have a blend door, but the noise sounds like its above the parking brake area.
