bucking/spuddering...anyone know possible causes
Old Jan 18, 2010 | 10:33 AM
rombout170's Avatar
rombout170
Default bucking/spuddering...anyone know possible causes
anybody know why when im driving my truck and i step on the gas just a little bit it starts to buck and spudder on me and almost acts like its running out of gas....but if i have it anywhere from half to full throttle it does nt do this!!
Old Jan 18, 2010 | 10:36 AM
rombout170's Avatar
rombout170
Default truck details
its a 95 1500 5.2L
Old Jan 18, 2010 | 10:48 AM
95RAM360's Avatar
95RAM360
could be the fuel pump they are typically a common problem..
also do a search for the plenum gasket, there are multiple symptoms for this issue and every magnum engine has this problem.
Old Jan 18, 2010 | 10:50 AM
halfamil's Avatar
halfamil
When is the last time it was tuned up ?
Old Jan 18, 2010 | 12:27 PM
yakkier's Avatar
yakkier
My durango was doing the same thing when i drove it last. hasnt been touched in 2 years though
Old Jan 18, 2010 | 12:37 PM
rombout170's Avatar
rombout170
just did plugs and wires, oil change, lube and head gasket. i also used fuel injector cleaner and put higher octane gas in to try to clean out the system. someone said it might be water in the gas so i put in a bottle of gas line antifreeze or dry gas to see if that worked and so far it has nt...i was also thinking its something fuel related maybe fuel filter...id say maybe fuel pump too but normally they just go they dont give much warning.... i am just interested to see what other peoples opinions on this are
Old Jan 18, 2010 | 12:48 PM
yakkier's Avatar
yakkier
id replace the fuel pump, if i remember correctly our tanks have the sock filter which is attached to the pump. So you will be changing the pump and filter in one. unless u have an aftermarket pump with an inline filter
Old Jan 18, 2010 | 01:07 PM
rombout170's Avatar
rombout170
ok thanks....does anybody else know if the fuel filter is in the fuel pump on the 95 1500 5.2L. or have any other ideas for what may be the cause....like i said before i was figuring it to be something fuel system related... i just dont understand why it only does it when im into the gas a little bit and not if im im 1/2 throttle or better
Old Jan 18, 2010 | 01:51 PM
halfamil's Avatar
halfamil
Make(triple check) sure your wires are in the right order, seated, and routed correctly.Wire routing is critical.
Old Jan 18, 2010 | 02:02 PM
halfamil's Avatar
halfamil
Here is a guide for your wires http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
