A/C Vents only run on high
Old Jan 19, 2010 | 01:13 PM
War Hammer's Avatar
War Hammer
Default A/C Vents only run on high
Hi all! I have a 2001 Ram 1500 Quad Cab 2wd with the 5.2L V8.
The other morning the A/C & heater vents stopped working on any setting other than the highest. The A/C still cools and the heater heats, and all of the functions (dash, floor, defrost, etc...) still work. But the fan speed only works on high; the three lowest settings give me nothing.
What do you think? Is this probably a dead switch and I need to replace the little panel that has all three dials? Is there some other problem that may be causing this? Is there a way to diagnose the switch to know for sure before I drop $160 on a new switch panel?
Old Jan 19, 2010 | 01:18 PM
pcfixerpro's Avatar
pcfixerpro
It doesn't sound like the switch to me. It sounds more like the fan motor resistor
Old Jan 19, 2010 | 03:28 PM
95RAM360's Avatar
95RAM360
+1 ive had the same proble in 2 previous vehicles...one was a pontiac sunfire, one was an olds cutlass. both turned out t be the resistor.
Old Jan 19, 2010 | 03:46 PM
yakkier's Avatar
yakkier
switch is an easier fix though lol
Old Jan 19, 2010 | 03:58 PM
meanwhitemopar's Avatar
meanwhitemopar
just cause it is an easier fix, doesnt mean tis the part thats bad
Old Jan 19, 2010 | 04:00 PM
yakkier's Avatar
yakkier
I know, just sayin hes gonna be wishin it was the switch.
Old Jan 19, 2010 | 04:01 PM
meanwhitemopar
true... but still... i would change it sense im already workin on it... but yea, sounds like the resistor
Old Jan 19, 2010 | 04:09 PM
pcfixerpro's Avatar
pcfixerpro
Care to explain why?
Edit, only reason I ask is... anything to do with the dash I don't consider easier than anything haha. I cracked the bezel last time I removed it, and then more cracks showed up too. At least in my case I would be happy that it was the resistor lol. Either way, here you go OP.. it is only a few steps.
Old Jan 20, 2010 | 08:38 AM
War Hammer's Avatar
War Hammer
Thanks pcfixerpro! This was very helpful. It looks like a farily easy fix and the resistor is only a $50 part versus $160 for the switch panel.
Old Jan 20, 2010 | 10:37 AM
iwhitne's Avatar
iwhitne
i'm going to have to do the same thing.. mine went yesterday while on the way to pick up other parts
