Tune up problems ?!
Old Jan 19, 2010 | 03:30 PM
yakkier's Avatar
yakkier
Angry Tune up problems ?!
I just did a full tuneup, oil,filter,plugs,wires,tranny fluid, tranny filter. i was driving to work this morning and the damn thing just basicly killed out then came back on an started running almost like i was out of gas. spitting an no power, i know i have gas because i filled it up before work this morning. only thing i can think of is the fuel pump/filter cause iv never changed it.
Old Jan 19, 2010 | 03:33 PM
95RAM360's Avatar
95RAM360
could be the fuel pump. also the dist. cap may need replacing
if the #3 & 5 wires touch it can cause misfiring because they fire right after one another.
may have crossed wires?
Does it throw a CEL?
PurplDodge's Avatar
PurplDodge
The fuel filter is not serviceable in our trucks, and doesnt need replaccing.
Make sure your spark plug wires are routed correctly on the distributor cap. You probably crossed a wire and now your truck is missing.
J415's Avatar
J415
did you route the plug wires according to the TSB? That could cause it to misfire.
All 3 of us responded at the same time 3:33
Old Jan 19, 2010 | 03:38 PM
yakkier's Avatar
yakkier
wires are just like they were before i did the tune up, all are in order because i do them one at a time as i do the plugs. I made that mistake when i was 15 with my nova and iv never done it since. our trucks have sock filters dont they ? my durango does and it seems like it has the same fuel system although my durango is a 360?
Edit:
it's not throwing any codes thats kinda whats trippin me out and i know my CEL works cause it threw a code a few weeks ago for a misfire on cyl 2
Old Jan 19, 2010 | 03:41 PM
PurplDodge's Avatar
PurplDodge
Check your plug wires again, though. You may never know, but maybe you didnt push the terminal all the way into the plug or something.
Aubrey's Avatar
Aubrey
No sock filter. I bet you didn't get one of the wires all the way seated on the cap and it moved a bit and is missing. Start grabbing all the wire ends and make sure they are on good and you have no boot/wire connecton issues.
Old Jan 19, 2010 | 03:44 PM
yakkier's Avatar
yakkier
i'll check again when i get back to the shop, i messed with it when i left the shop this morning to run my route. didnt have a chance to test drive it and see if it did ne thing. although i will admit it was kinda a bit getting the coil wire to seat on the destrib
Old Jan 19, 2010 | 05:37 PM
95RAM360's Avatar
95RAM360
yes this can happen, when i did mine, the #1 left side wasnt clipped down and i thought it was...its a tight fit for all the boots to fit on the cap
Old Jan 19, 2010 | 09:58 PM
yakkier's Avatar
yakkier
yea no idea, everything is working fine now. It ran like **** when i first started it when i got back to the shop, i got pissed and basicly leveled the throttle for about 30 seconds redlining it and now it's fine, maybe a burp in the fuel system ?
