tuner...
Old 01-20-2010 | 03:21 AM
offroadjosh's Avatar
offroadjosh
Default tuner...
Is there anyway to get a tune or flash my PCM(like to get rid of the death flash) with out buying a tuner?
Josh
Old 01-20-2010 | 03:36 AM
dodge15004x45.9's Avatar
dodge15004x45.9
NO!!!!
Old 01-20-2010 | 03:47 AM
Laramie1997's Avatar
Laramie1997
Yes you can.
Get a MOPAR Performance PCM or send yours off for a custom flash.
A hypertech would be the cheaper option of the other two options though.
Old 01-20-2010 | 03:50 AM
dodge15004x45.9
He said with out getting a tuner.
I don't think he wants his truck down for a few days while his PCM is out getting reflashed.
Pcprofixer is having issue's with his PCM.
A PCM change isn't buying a tuner. True, it's a technicality, but it is the only way to rid himself of the death flash. As I said, hypertech would be the cheaper way out. While still being a tuner, it usually doesn't have near the issues that superchips has (Sometimes)
Being that you have OBDI, a Hypertech tuner is about the only option you have except for PCM changes/Flashes.
dakotas ram's Avatar
dakotas ram
about 1/3 of the way down
http://www.bgperformancepcm.com/
do you have the death flash?
Old 01-20-2010 | 03:51 AM
dakotas ram
laramies options are without a tuner and the mopar pcm doesnt require sending out your pcm
Old 01-20-2010 | 04:02 AM
Laramie1997
Max, I mentioned a hypertech for costs alone. There is two options avaliable to the 96 since it is an OBDI interface. That being so, he can only use a hypertech tuner, get a custom PCM flash, or get a MOPAR performance PCM.
Old 01-20-2010 | 12:29 PM
offroadjosh
I have OBD II... Right? I have an OBD II port and can pull codes with my scanner.
Old 01-20-2010 | 12:41 PM
nopower318's Avatar
nopower318
The only real way to get ride of death flash is to get a tuner or like Laramie said is the Mopar performance PCM, 1996 was the first year for the OBDII and SCT is I think the only tuner out that can flash the 1996-1997 trucks.
Old 01-20-2010 | 12:57 PM
offroadjosh
Hmm well thanks for the info guys=P I was hoping I could go some where local and just have it flashed haha. How much is a mopar PCM?
