Stock foglight wiring harness and mounting options ?
Old Jan 21, 2010 | 08:26 PM
yakkier's Avatar
yakkier
Default Stock foglight wiring harness and mounting options ?
Just curious if any one knows if all of the wiring harnesses are the same, since my truck didnt come with stock foglights, although it does have the cutouts on the bumper for them. Im wondering if the wiring harness is factory built for them if i can find the connections and also shouldnt the connections for the switch be inside the dash some where, i looked in my fuse box it has the sockets for the fuse for them, just no fuse in it.
On a different note, iv seen a few guys on here have KC lights or fog lights on the bumper behind the grill and i was wondering if any one has pictures of how the wires are ran and opinions on what type of lights and what you guys think of how they look.
Old Jan 21, 2010 | 08:32 PM
PurplDodge's Avatar
PurplDodge
Just build your own harness. No sense in screwing with the thin factory wires.
And yes, factory fog lights will fit in your truck. My truck didnt come from Saltillo with fog lights. I just swapped in the bezels, painted them orange, and mounted them in. I got it all at a junkyard for $30. Also, get fog lights from a 99-01 truck, they look much better.
Old Jan 21, 2010 | 11:36 PM
PurplDodge's Avatar
PurplDodge
Originally Posted by PurplDodge
The best way to wire up lights is to use a relay. This takes the load off the switch, and will reduce the amount of voltage drop to the lights, making them brighter (These lights will be brighter than your stock harness) Using high quality 10 gauge wire (Dont bother getting it at parts stores, I get mine at RadioShack) run 2 wires directly from the battery. One will go to the switch, and the other to the relay. Get whatever switch you want (the Shack has many different varieties) and mount it wherever you want in the cab. Run one of the wires to the switch (Switch will come with scematic). Then, put in a ground for the switch. The last connector for the switch will go to the relay to trigger it when you turn the switch on.
Now for the relay:
Mount the relay on the firewall, where it is easy for you to access. Run the wire from the switch to Pin 86 on the relay. The wire from the battery goes on Pin 30. Pin 85 is ground. Pin 87 goes to your lights.
That should help you with your new wiring harness.
Also, I forgot. You need to put a fuse on the power wire that goes to the relay. I used a good waterproof Bussman fuse.
What that dumbass said.
Old Jan 23, 2010 | 08:24 PM
codyselcamino's Avatar
codyselcamino
will the switch from a fog light equipped truck fit on a non fog light harness? i have the same problem and i hate toggle switches, i would like to keep it stock as possible by using the factory harness too, theres a relay in my under hood fuse box, i have no problem running a wire from that down but i really dont want any more coming from my fire wall i have have enuff of those already
Old Jan 23, 2010 | 08:30 PM
yakkier's Avatar
yakkier
I broke down and wired in a toggle switch, i didn feel like fishing through those wires. But it's clean enough that it doesnt really bother me
Old Jan 23, 2010 | 11:22 PM
codyselcamino
as much as i hate to sort through the wires, i hate the look of toggle switches more, and im currently laid off so i got time haha
Old Jan 23, 2010 | 11:24 PM
011500Ram's Avatar
011500Ram
Why in the world would you use 10awg for fog lights? They pull what, 35 watts each? That's 5 amps at 13.5 volts. You could use a 14 awg wire and be just dandy. High quality wire wont be found at Radio Shack by the way. That's all made in China. Get some high strand count Stinger wire or the like.
Old Jan 25, 2010 | 04:59 PM
PurplDodge's Avatar
PurplDodge
Why not (use 10g)? AFIC its the same price as 14g wire. Plus using a thicker wire allows me to upgrade to a bulb that is rated for 55 watts in the future. By high quality, I meant the stuff at Radio Shack is higher quality than what is found at AutoZone. Anyways, AutoZone's prices on wire is jacked up.
BTW, where can I get Stinger wire?
Old Jan 25, 2010 | 05:14 PM
011500Ram's Avatar
011500Ram
Because 10awg is ****ing huge. The OD of 10awg is .102, where as the OD of 14awg is .064, nearly HALF the size. Thicker wire won't allow you to upgrade to 55 watts. You don't need thicker wire. A pair of 55 watt bulbs still will only pull 8.14 amps@13.5v. 14awg will support up to 17A, enclosed. Heck, a pair of 55 watt lights could be run on a single piece of 18awg, which will support 10A enclosed.
I've never understood why people go for the overkill awards with wiring. Read a Ampacity chart. Save yourself and your wallet the trouble of running obscenely large wire, that is doing the exact same job that a wire far smaller could safely accomplish.
Also, you want dim lights for fog lights, not the other way around. The only purpose of a fog lamp is to illuminate the edges of the road, and the immediate proximity in the foreground. They are not designed to provide light for driving. If you put brighter bulbs down there, you are better off driving with just your parkings lights on in a real world fog situation.
Old Jan 25, 2010 | 05:22 PM
PurplDodge's Avatar
PurplDodge
Why not is what I always say. And, I made a typo, I used 12g wire, not 10g.
I can understand your point there. If I needed some brighter lights, I would get some Hella 500s and put them next to the fogs. And then get some yellow Hella 37.5 watt bulbs for the fog lights.
Where do you get Stinger wire?
