wickedly bright backup lights
Old Jan 29, 2010 | 12:37 AM
  #51
99Silver1500's Avatar
99Silver1500
I don't see how flashing the rear lights are any more dangerous then flashing someone with your headlights.
believe it or not, but your headlights are aimed away from the vehicle you would be flashing, there is no such rule about aiming your reverse lights, and specifically auxiliary lighting, which would be much closer to the drivers windshield, and forward point of vision, then your headlights would be.
also never known anybody to get hit with an attempted murder charge for hitting their brights.
Old Jan 29, 2010 | 01:50 AM
  #52
011500Ram's Avatar
011500Ram
you also need torches. torches make bending metal so much easier. especialy when you start trying to bend thicker stuff.
Use a press. Heating metal will destroy whatever treatment it has undergone.
Old Jan 29, 2010 | 11:58 AM
  #53
crazzywolfie's Avatar
crazzywolfie
not everyone has a access to a metal brake or a press. there is usually not much of heat treatment on something as thick as what sheriff used.
Old Jan 29, 2010 | 12:17 PM
  #54
011500Ram's Avatar
011500Ram
Bummer. Hire a shop to do it. There's no excuse for halfassing fab work. Just do it right, and you'll do it once.
Old Jan 29, 2010 | 12:31 PM
  #55
Miami_Son's Avatar
Miami_Son
Another example of how you can be so condescending. The part in question is not structural. Any heat application is not going to be a factor in whether it does what it is intended to do. While your statement has merit, in this application it simply isn't needed. Nitpick much?
Old Jan 29, 2010 | 12:51 PM
  #56
011500Ram's Avatar
011500Ram
Was I right?
Old Jan 29, 2010 | 12:55 PM
  #57
Sheriff420's Avatar
Sheriff420
on the heat to bend subject, for something like skid plates i'm sure it wouldn't really matter because if you hit them hard enough to break them then the plates would be the least of your worries.
if you were concerned about weakening them then couldn't you temper them to give back the strength that was taken away by the torch?
Old Jan 29, 2010 | 12:58 PM
  #58
011500Ram's Avatar
011500Ram
Skid plates are typically flat plates bolted to tubes, or crossmembers. One time use the lot of them
Old Jan 29, 2010 | 01:08 PM
  #59
Miami_Son's Avatar
Miami_Son
Was I right?
Is that all you're here for, to prove how right you can be on almost any subject? I'm guessing your constant need for attention and affirmation keeps your circle of friends at a small and manageable size.
Old Jan 29, 2010 | 05:20 PM
  #60
95MaroonMonster's Avatar
95MaroonMonster
Originally Posted by wake
i do the same exact thing
man i was on muh way home this morning...at about 3 am....some ****tard was tailgating me soo close i couln't see his headlights under my 'gate, left footed the brake a couple times, he passed me in the left turn lane...i gave him the bird
