Exhaust Ideas
Old Jan 24, 2010 | 04:28 PM
elementalnature's Avatar
elementalnature
From: Home: Southern KY; Stationed: Southern California
Originally Posted by lblair04
Thanks guys. As for the starting issue...it does it at the initial start up (does it in the summer and the winter, so not a temp issue) and it also does it if I shut my truck off for longer than 15 mins. Plugs just got replaced with the cap + rotor...starting issue was there before plugs.
Any other ideas? It runs good, but this is more of a problem that just pisses me off!
Also, for the exhaust I just drive normally...just looking for some grunt and to sound good. Wouldnt complain about a couple more mpg either.
Thanks again
If it is just initial, sounds like the fuel lines aren't staying primed and its taking a few seconds to build pressure. Before you start it in the morning, turn the key to the on position and don't start it. Just let the lines build pressure and after 30 seconds or so try to start. If it fires up I would be willing to bet that the pump isn't able to prime your fuel lines in the morning quick enough.
Old Jan 24, 2010 | 05:22 PM
lblair04's Avatar
lblair04
If the pump cant prime quick enough, would replacing the pump be the solution?
