seafoaming video
Old Jan 24, 2010 | 11:08 PM
lastrights's Avatar
lastrights
Default seafoaming video
me and my cousin decided too seafoam our trucks today his is a 98 and mine is a 2000, mine smoked alot more i dunno why http://www.youtube.com/watch?v=buc5cN1nZHM
Old Jan 24, 2010 | 11:24 PM
yakkier's Avatar
yakkier
Where did you put the seafoam, tank or intake ?
Old Jan 24, 2010 | 11:33 PM
yakkier's Avatar
yakkier
Found this video that might answer your question, this is actually a rep from seafoam. says that the reason why you might have had more carbin buildup than your friend
http://www.youtube.com/watch?v=hZyz-np6tDI
Old Jan 25, 2010 | 02:42 AM
Sheriff420's Avatar
Sheriff420
that is funny picture at the end of the vid. he's flashing a gang sign and a little bit of cash while squatting in front of his pos 20 year old van.
the rep lied too, dude asked if it would be ok to run with a half can of seafoam in his oil until the next oil change and the "retired ASE tech" said that it would be fine. now i've been told that you should change the oil within a couple hundred miles because it will degrade the oils lubrication properties pretty quick.
Old Jan 25, 2010 | 02:50 AM
011500Ram's Avatar
011500Ram
I wouldn't say he lied.. Is there any hard Data to either support, OR disprove his statement?
Engine additives are always a mystery concoction. 1 part chemicals, 1 part marketing.
Old Jan 25, 2010 | 03:31 AM
Sheriff420's Avatar
Sheriff420
well here it is from the seafoam site.
Using in Crankcase Oil
Sea Foam Motor Treatment may be used in an oil crankcase 2 separate ways, depending on your needs and expectations. Sea Foam Motor Treatment is most commonly used as a pre-service, old oil residue re-liquefier / cleaner and moisture drier. It can also be used as an after-service oil additive. In either application, Sea Foam Motor Treatment will safely and slowly re-liquefy old oil residue. Each method is described below:
  1. As a pre service cleaner for old oil residue, sticky rings or valve train noise, pour 1 ½ ounces of Sea Foam Motor Treatment into the engine oil crankcase for EACH quart of oil capacity, including filter. Drive a MINIMUM of 30 minutes/miles, MAXIMUM 100 miles, and then do your oil change service – Lube, Oil & Filter (LOF). This begins the process of safely/slowly re liquefying the old oil residue so contaminants may flow and be filtered. This also makes your old oil dirtier, quickly, so a LOF service is necessary when the oil gets dirty. Great for Turbocharged & Supercharged applications where oils deteriorate so quickly due to heat, and leave those residues that NEED CLEANING.
  2. As an after service additive into fresh oil, nearly fresh oil, or oil (used condition) that is NOT ready to be changed (based on mileage since last oil change), put the same amount of Sea Foam Motor Treatment into the crankcase as described above, and then regularly monitor your oil for color and clarity. Set a predetermined schedule for checking the oil condition on a mileage, timed, or event basis (like every time you add fuel, etc.) to determine when an oil service is necessary. Monitoring of the oil for color and clarity will tell you when it is time to do an oil change service. NOTE: Do not exceed 3,000 miles without changing the oil.
Sea Foam is safe to use with all synthetic oils. 100% synthetic oils, and blends of synthetic and petroleum-based oils, were engineered and are manufactured to be 100% compatible with petroleum based oils, all brands, and vice/versa. Without this compatibility, oil manufacturers and engineers would be liable for the results of mixing non-compatible lubricants. Since Sea Foam ONLY contains petroleum oils, it is entirely compatible with synthetic oils.
Remember! When Using Sea Foam in Your Crankcase:
  • Check your oil and monitor its color & clarity to determine need for LOF service!
  • Change your oil when it gets dirty!
so if the pre service cleaning didn't get all the crap out then you will have to change your oil again pretty quick.
so i guess the guy didn't lie. the picture is still funny though.
Old Jan 25, 2010 | 03:50 AM
Laramie1997's Avatar
Laramie1997
Not to mention, it says it right on the can. Something like change oil within the next 100 miles or something like that.
Old Jan 25, 2010 | 02:14 PM
lastrights's Avatar
lastrights
my cousin with ther blue ram runs 15-40 diesil oil in his, i run 15-30 mobil 1 sythetic
Old Jan 25, 2010 | 02:54 PM
jps's Avatar
jps
HAHA thats Canadian Tire money
Old Jan 25, 2010 | 03:37 PM
98Blue-Ram's Avatar
98Blue-Ram
Where would one get a sticker like that one? "Eats Fords and $hits Chevys"
