More lift.
Old 01-25-2010 | 02:12 AM
nopower318's Avatar
nopower318
Default More lift.
So I have to replace the front axle, while I'm under there I might as well add some more lift. I'm going with a 2.5'' coil spring spacer, drop track bar bracket, drop pit-man arm, and some other things. All in all it should be at a total of 5.5'' of lift in the front, however what would I need to level the rear with the front? I think a 4'' AAL should make it level, but I'm not sure. What else do I need? I already have longer control arms as they came with my skyjacker 3'' kit, and I don't need sway-bar drop brackets as I don't run one anyway. I'm getting all this stuff from top gun customz with some RC shocks. I'm doing all this at once so it is going to take some time, just getting ready for some 4.56's and some 35's.
Old 01-25-2010 | 04:38 AM
dodge15004x45.9's Avatar
dodge15004x45.9
You need longer control arms for that much lift in the front.
The aal should fix the rear.
New shocks all 4.
Old 01-25-2010 | 07:37 AM
95RAM360's Avatar
95RAM360
are you getting 3/4 ton coils? or 1 ton coils? for front
and rear, the AAL should do the trick since the rear is like 2 inches or so higher than the front.
Old 01-25-2010 | 12:13 PM
nopower318's Avatar
nopower318
I have skyjacker 3'' lift coils now, and new shocks are a must. With the lift on now the control arms are almost level with the ground and the skyjacker kit came with lower and upper control arms but I just never got around to putting the new uppers on. Are new control arms needed? from research all I can find is that it will ride rough and that don't brother me.
Old 01-25-2010 | 02:14 PM
Gav1n8's Avatar
Gav1n8
I would put them on but you could probly get away without them.
Old 01-25-2010 | 02:22 PM
yakkier's Avatar
yakkier
I would just block the rear's, and im glad to hear you're on your way to fixing it back up.
Old 01-25-2010 | 02:31 PM
Gav1n8's Avatar
Gav1n8
Why block the rears? It's not that exspensive for AAL's and stacking blocks isn't exactly a smart thing.
Old 01-25-2010 | 02:34 PM
yakkier's Avatar
yakkier
Mine were stacked, i never had any problem out of them. You just have to make sure they'er installed right
Old 01-25-2010 | 02:38 PM
Gav1n8's Avatar
Gav1n8
I know many who have... He would be stacking a 4 inch block on top of his factory block. I run 42's with stock axles and haven't had any problems. That doesn't mean it's not dumb.
Old 01-25-2010 | 02:43 PM
yakkier's Avatar
yakkier
Doesnt mean it is dumb. To each their own
Quick Reply: More lift.
