windshield washer... no workie
Old Jan 30, 2010 | 11:24 AM
meanwhitemopar's Avatar
meanwhitemopar
Default windshield washer... no workie
i checked both fuse panels, and i have no blown fuse.. i looked at the thing that plugs into the resivour... its good, i think, and there are no cut wires...
i push the switch in to wash, and i dont even hear the thing kick on... wipers still work..
Old Jan 30, 2010 | 11:32 AM
2001Ram's Avatar
2001Ram
I am sure its the little motor inside the washer tank. Its on the side with the wires running to it. I have seen them get clogged up with crap and cause them not to work, might try to clean it first. If not then its $16
http://shop.advanceautoparts.com/web...EAMS_202654844___
Old Jan 30, 2010 | 11:38 AM
meanwhitemopar
crap... ok... no biggie, i m going to have to make a mess in the parking lot, go pull the motor out of it... let it drain... and try clean... if not.. its just plug and play right?
Old Jan 30, 2010 | 11:45 AM
dhvaughan's Avatar
dhvaughan
check for voltage at the pump motor when you turn on the switch.
no power = wiring or fuse problem.
power at the motor = bad motor.
Old Jan 30, 2010 | 12:00 PM
meanwhitemopar
that is a good idea.. didnt even think of that... what kind of power should be there?
Old Jan 30, 2010 | 12:03 PM
VEETEN's Avatar
VEETEN
12 vdc
Old Dec 10, 2013 | 12:32 AM
goB1Gred ram's Avatar
goB1Gred ram
I wonder does this apply to 1996 ram?
Old Dec 10, 2013 | 08:51 PM
dhvaughan's Avatar
dhvaughan
yes..
