tranny?? with cold
Old Jan 31, 2010 | 12:24 PM
contractorben's Avatar
contractorben
Default tranny?? with cold
Hey guys, question that is killing me. On my 01 5.9 4x4 1500 with 104,000 miles on it. When I crank it up in the morning and put it in drive the truck seems to be having a power slip, if I punch the gas a little it will wait a sec then go. About a week ago it was like chugging, put it in neutral then drive couple of time then pull off road put it in park then drive still did it. Then I when and put in 4wheel high then back to 2wheel high, then drive down the road with out a hitch. Does not act up later in day. Now trany or transfer case i dont know. Have any of yall had this?? Please help. Also live in georgia so not that cold.
Old Jan 31, 2010 | 12:29 PM
lane's Avatar
lane
have you checked the fluid?
Old Jan 31, 2010 | 12:35 PM
contractorben
no but that that just made a lot of sense i feel like a dumb axx now, however if it has been cold for a while why would it start doing this now? I will check today though.
Old Jan 31, 2010 | 06:53 PM
contractorben
well i looked at the trany fluid level and it is in between the cross marks with the truck hot. Fluid was pink and didnt smell burnt or anything, and seems to go away after truck is tranny gets hot. Open to any input. Thanks, Ben
Old Jan 31, 2010 | 07:34 PM
contractorben
Reading my hanyes book it said when truck is hot fuild should be in to the top of the cross marks on the dipstick. Would this make big deal?
Old Jan 31, 2010 | 07:53 PM
Gerehead8's Avatar
Gerehead8
It shouldn't make that big of a difference but I would top it off. Try putting it in neutral for a few seconds then putting it in drive. Tranny fluid flows through the tranny in neutral.
Old Jan 31, 2010 | 07:56 PM
contractorben
well I taught i was supposed to measure it in neutral? Thats is what I did, did I get a bad read?
Old Jan 31, 2010 | 08:16 PM
lane's Avatar
lane
he doesnt mean when you are checking the fluid, he means put it in neutral for a few seconds before you drive off when the tranny is cold.
Old Jan 31, 2010 | 08:22 PM
Kawman10's Avatar
Kawman10
I'm no trans expert but My Dakota did the same slip in drive. unless I let it run a min or 2 in Neutral before going to drive. If you try that I bet you will feel it shift into drive. Have done it for 4- 5 yrs on my dakota that I just sold. Had no problems as long as I let the fluid run thru in Neutral. Cold here in NJ during the winter also.
Old Jan 31, 2010 | 08:39 PM
contractorben
Thanks guys i just smiled reading this. So should not be any major problem right? I will give a try will respond with answer.
