auto to manual swap
Old Feb 7, 2010 | 01:43 PM
meanwhitemopar's Avatar
meanwhitemopar
ok, now i read it and it says it rated at 300 ftlbs... doesnt a stock 318 put out more then that already?
like i said, i just need a trans that wont completely kill me, but yet still be stong enough...
i noticed the nv4500 has the same bolt patern as the 95-05 gm vehicles...
anyone hear of a turbo 400 trans behind a 360?
Old Feb 7, 2010 | 02:01 PM
yakkier's Avatar
yakkier
iv heard of people trying, but never seen any result's from it. Dude i'd just say rebuild a stock one and run with it. OEM isnt that bad
Old Feb 7, 2010 | 02:13 PM
pcfixerpro's Avatar
pcfixerpro
You first need to figure out what your trying to gain before you do anything. If your goal is to make things very complicated for yourself, then do the above.
Old Feb 7, 2010 | 02:17 PM
audiomechanic's Avatar
audiomechanic
If you have a donor truck, the swap should be relatively straight forward. I'd go with the 4500 personally (especially since that's what I'll be going with when I do mine ).
Find a Ram 2500 with the 360 and a stick and you'll have everything you need for the swap. Might need to buy a new clutch though.
Old Feb 7, 2010 | 02:25 PM
yakkier's Avatar
yakkier
why wouldn you just buy a 5.9 2500 with a manual tranny already in it, with a blown engine or whatever and take the parts off your truck to fix that one. instead of trying to turn an automatic into a manual
pcfixerpro's Avatar
pcfixerpro
Good luck!
Old Feb 7, 2010 | 03:49 PM
MrRuckuss's Avatar
MrRuckuss
bullit proof the tranny you have now, that would be a better option, not sure what you have done to it as far as rebuild, but i would take it somewhere and have it professionally redone with high performance parts. you will have less of a headache swapping to a manual or another trans like the 727. just my $.02
Old Feb 7, 2010 | 05:30 PM
meanwhitemopar
yea, if i could just bullit proof my 46re, i would love it... cause i love my shift points, and the auto part of it, i am kinda used to how this trans operates...
so like i said, i am gettin the one i have rebuilt, again, under warrentee and go from there... just so i can run it again, and hope its under warrentee next time too... lol
as of right now, i am going to be rebuilding the old 318 out of this truck, just to make the bit better then stock power and do the 5.38 gears, so ill have plenty of power to the ground... only thing im worried about, is me making around 320-350hp to 40" tires... how well will that work... lol see my point?
Old Feb 8, 2010 | 10:11 AM
quackaddict's Avatar
quackaddict
Yeah if you could find a 2500 that had a 360 5speed with a 4500 the bellhousing is differnt but the transmissions is the same size bolt pattern etc as the 3500 and will bolt right up to your 360 still have to do all the swap stuff. The 4500 they used in the diesel and V-10 has bigger shafts.
I actually found one here locally that was a 2500 with a NV4500 but he had sold the transmission to a chevy guy so he gave me the Bellhousing for it. Now all I have to do is find a dodge or chevy 4500 out of a gas motor and it will bolt right up. Speaking of which Chevy put a lot of 350's in there late 90's model 2500 and 3500 trucks so this transmission is acutally more common than you would think.
Just make sure the donor dodge is a GAS 360 2500
–Dodge Ram
Chrysler Corporation Dodge Truck division used the NV4500 as NVG4500 in "Standard" and "Heavy Duty" applications.[2]
Shared Standard Duty & Heavy Duty Features:
  • Dodge NV4500 Transmission to bellhousing bolt pattern (shared with the 1995–2005 GM light trucks)
  • Dodge specific input shaft 7.5" long with .725" diameter pilot shaft diameter & spline count varies
  • Concentric internal hydraulic clutch slave cylinder with integrated throwout bearing
  • 1992.5-1997 2wd Gear drive speedometer in tailhousing Some 1998 may have gear drive
  • 1998-----UP 2wd no speedometer gear (VSS in axle)
Standard Duty 1992.5–2005 order code DDP:
  • All Years have Dodge small block bellhousing to engine bolt pattern
  • 1992.5–2002 Used with 5.2, 5.9 V8
  • 2003–2005 Used with 5.7 Hemi
  • 1992.5 only 1" diameter 19 Spline input shaft
  • 1993-----UP 1.125" diameter 10 Spline input shaft
  • 1992.5---UP 2wd 30 spline output
  • 1992.5-2000 4wd 23 spline output
  • 2001-----UP 4wd 29 spline output
Heavy Duty 1994–2005 order code DDX:
  • All Years used with 5.9 Cummins Turbo Diesel and 8.0 V-10
  • All Years 5.9 Cummins Turbo Diesel & 8.0 V10 bellhousing to engine bolt pattern
  • All Years 1.25" diameter 10 Spline input shaft
  • All Years 2wd 31 spline output
  • All Years 4wd 29 spline outp
12345R5.613.041.671.000.735.61 (to 1997) 5.04 (1997 on)
