Hello Guys,
Was going through the machine I just bought, and the Vacuum Shift Motor was snapped off the the PO. Anybody know how hard it is to remove it when it's leveled and were a good place to get one would be?
Thanks,
Brandon
1995 Dodge Ram 2500 w/ Dana 60 Front Axle
Thanks,
Brandon
not too hard to remove, but use penetrating oil on the 4 little dinky bolts, as they tend to snap off.
i would NOT spend much money on a replacement vacuum CAD, as its a POS even when it works right. a new one is probably expensive, more than $100. you might get a cheap one at the junk yard and clean it up so it works.
what you might want to put in a posilok cable for under $200.
http://www.amazon.com/Posi-Lok-PSL40.../dp/B000FPXSY0
yes, just cap them off anywhere between t-case and cad. on a lot of trucks the lines are broken or kinked along the transmission cross member. mine were.
