Axle diameter?
Old Feb 2, 2010 | 12:12 PM
torp74's Avatar
torp74
Default Axle diameter?
Does anybody know what the axle diameter is for my '02 2500 with the V-10? Seems the 2500 had a 3" and a 3.75" axle. I am out of town this week so can't go measure it myself. Thanks!
Old Feb 2, 2010 | 12:50 PM
95RAM360's Avatar
95RAM360
i hope this helps...
Used on 2500 with automatic and V10 or Diesel
Axle Type
Hypoid
Lubricant
Thermal Stable SAE 80W-90*
Lube Capacity
4x2
4x4
7.0 pints ( 3.311 L )
7.75 pints ( 3.666 L )(a)
Axle Shafts
35 Spline, 1.50" diameter
Axle Ratio Options
3.54, 4.10
Carrier Split
.4.10 and down, 4.56 and up
Ring Gear
Diameter
Backlash
10.50 in. ( 266.7 mm )
0.004- 0.009 in. ( 0.10- 0.23 mm )
Pinion Standard Setting
5.375 in. ( 136.525 mm )
Pinion Bearing Preload
Original Bearing
New Bearing
10- 20 in. lbs. ( 1- 3 N.m )
20- 40 in. lbs. ( 2- 5 N.m )
Traction aids available:
Lockright
Detroit locker
Truetrac
Auburn Limited slip
ARB Air Locker
Dana Bill of Materials #1994-95 2500 2WD6055901994-95 2500 4WD6055881996 2500 2WD605787* Power-lok differentials require the addition of 8 oz of friction modifier.
(a) A report on the TDR forum says it takes 3 Qt. to refill
take a look at this as well
http://en.wikipedia.org/wiki/Dodge_Ram#Axles
Old Feb 2, 2010 | 12:59 PM
yakkier's Avatar
yakkier
ripley did u get my pm about the vacume lines?
Old Feb 2, 2010 | 01:01 PM
95RAM360's Avatar
95RAM360
yep...pm sent
Old Feb 2, 2010 | 07:47 PM
VEETEN's Avatar
VEETEN
I ran out and measured my front real quick and got 3 1/2"
It's pouring out so I'm not gonna double check..LOL
From my poor memory 2000-2002 was the last years of the Danas on Dodges and are different from the previous years.
Now all that aside I would say the standard 2500 has the 3" the v-10, and diesel are the 3 3/4"....
anyway my front is Dana 60 and back is Dana 70
which one are you looking for?
Old Feb 3, 2010 | 08:41 AM
torp74's Avatar
torp74
VEETEN you are the MAN! I have the Dana 60 up fron as well. Everything I have read is that the 2000-2002 were the last of the breed as well. Thanks again.
Old Feb 3, 2010 | 06:45 PM
VEETEN's Avatar
VEETEN
I just remeasured and got the same 3.5" front and back......
So I'm stumped on this one..
Is the 3" axle refering to the ID (if so that's what I have)
But I dunno, I think the axle tube is thicker than 1/4" wall.
I think we need an expert to chime in here first.
What are you looking to buy/replace on the axle?
Old Feb 4, 2010 | 07:48 AM
torp74's Avatar
torp74
This is the best axle info I could find here. It says the axle thickness is .50
I am getting a dual steering stabilizer and need the OD. I am almost positive it is the 3.75. Worse case if I am wrong will just need some different U-bolts.
Old Feb 4, 2010 | 07:03 PM
VEETEN's Avatar
VEETEN
Let me know how it works out, cause now I'm curious...
