putting in a 5 speed
Old Feb 2, 2010 | 04:42 PM
Lowridetractor's Avatar
Lowridetractor
Default putting in a 5 speed
well i tried doing a search but no success. but anyway i got my truck back from the local trans shop and it turns out that 2nd gear is completely gone. so instead of rebuilding it or putting in another junk one i want to put in a 5 speed. anyone do this? and any complications? thanks
Old Feb 2, 2010 | 04:45 PM
95_318SLT's Avatar
95_318SLT
Well I know its a Dakota, not a Ram, and OBDI instead of OBDII, but you could start by reading through my post here to get an idea...
https://dodgeforum.com/forum/1st-gen...-5-2l-4x4.html
Or here is 2nd gen Dakota write up. Again, not a Ram, but at least it deals with the OBDII electronics...
https://dodgeforum.com/forum/2nd-gen...sion-swap.html
Old Feb 2, 2010 | 04:46 PM
PurplDodge's Avatar
PurplDodge
Basically, you need the transmission, the clutch, clutch hydraulics, and a computer flashed for a manual transmission.
Old Feb 2, 2010 | 04:53 PM
Lowridetractor
whats the diff. between a manual and auto ecm?
Old Feb 2, 2010 | 04:59 PM
95_318SLT's Avatar
95_318SLT
An auto PCM expects to run the transmission, and if it doesn't see the transmission is there, will throw CELs. On my OBDI computer, that was not a big deal... the CEL didn't stay on, just simply stored the codes and did not change how it ran the engine. On your computer, however, it will throw the truck into "limp-in" mode and your engine power output will be severely limited.
Old Feb 2, 2010 | 05:07 PM
PurplDodge's Avatar
PurplDodge
Yes, this would be true.
Lowridetractor
oh thats ok i took my cel out because my cat is gutted and i didnt want to look at it anymore
edit* i didnt read the rest of what you said thats a shame
Old Feb 2, 2010 | 05:09 PM
jasonw's Avatar
jasonw
Site Moderator
I would try to nab a 5-speed manual from a 2500 5.9L V8, a NV4500. Stronger than the 5.2L/3.9L's NV3500 manual in the 1500s.
The NV3500 may work just fine (it'll bolt up), but it's not designed to handle the higher torque/power of a beefed up 5.9L V8 if you beef the engine up later. Stock, you should be OK.
Old Feb 2, 2010 | 05:12 PM
Lowridetractor
thank you for all the info guys and 95 318 thats was a good write up thank you
Old Feb 2, 2010 | 05:24 PM
Bubba39047's Avatar
Bubba39047
Edit: nevermind. posted before reading. Jason is exactly correct. The NV3500 is a good tranny and would do the job for that 5.2 unless you tow a lot etc. but just drivin, doin burn outs etc. it'll do just fine. I've got it in my v6 and i hate the motor, but the tranny is nice. Shorter clutch than the NV4500 to for slightly qicker shifts.
